I have some Aeotec sirens and bits that used to work with smartthings but now do not (V2 Hub)
Do i now need a V3 hub or an Aeotec Hub or are they both the same?
You do not need a new hub. Can you describe the issue with the aeotec siren? what edge driver is it currently using?
If it is a sound issue, check out this thread: https://community.smartthings.com/t/aeotec-siren-6-unable-to-set-sounds-with-edge-driver/243006
When i try to pair it with smartthings it just keeps saying you need a hub?
iOS or Android app? does the color of the led change on the hub when trying to pair the device?
try scanning for z-wave device instead of by brand > aeotec
Could be location issues… Might not be pointed to the same location where the hub is. ![]()
Thanks guys il give it a try
