I just added an Aeotec Door/Window Sensor 7 (Gen 7) to my smartthings hub, but when I check the device it only shows me the battery life. There’s no info on whether or not the sensor is open or closed.
If I place the two pieces close together I see a red light go off from the device, so it looks like the hardware is detecting a change. I just don’t know why the closed/open status is not shown in the smartthings app.
Yes, I’ve had similar issues. Try excluding the device from the Z-Wave utilities inside the hub menu, pair it again, this time a couple feet from the hub, give it a few minutes.
If that doesn’t work, check inside the IDE to see what device type it’s assigning it. You may need to switch it to a Z-Wave open/close sensor.
Manually switching it to a Z-Wave open/close sensor seems to add the Open/Close status now, but unfortunately the sensor status doesn’t seem to be updating at all.
