Aeon Micro Smart Energy Switch - not pairing
I’ve been trying for days now to get any of my Aeon Micro Smart Energy Switches to pair with my Smartthings Hub.
I have 3 already fitted in the wall switches and they work fine, but the red light just keeps flashing and they are never seen by the Smartthings Hub. I resorted to set up a small setup rig that allows me to connect main supply to the other 3 Aeon switches and locate then right next to the Hub, but although they work fine as switches, they never seem to be seen by the Hub.
So, I have 6/6 failures and days of trying everything I can think of, so either I am doing something consistently wrong, or I have 6 faulty devices…
The promising part is if I push the Aeon switch’s button 6 times in rapid succession, the red LED on the switch flashes rapidly for about 5 seconds, then resumes it’s slower flashing. My Smartthings app just sits there searching for apps and never sees a thing.
I really need some good ideas or experiences to get these things to work, else I may just toss the blasted things out the window.
What’s the model # off the switch. New gen 5s may have trouble pairing.
You are using things, connect new device correct?
I have 20 plus of these, not had an issue pairing them ( I pair them off an extension cord, right next to the hub)
Post install, I run a zwave repair.
Model number is: DSC12103-ASAP
How can I tell the version?
I use the ST app to add a new device and while it searches, I press the Aeon switch’s button. At this stage no matter how many times I press that button, it is never found by the ST.
Where did you buy these?, all the US version part numbers end in US as in ZWUS
Even Mr.G can’t find that exact PN, only a DSC12103 which is a Generation 1 antique, suitable for museum display…
I bought these switches off eBay without realising that there was any generational requirement for supporting z-wave devices.
Can these Gen 1 types be paired with ST?
I’m thinking the reason they don’t pair, is that they aren’t using the correct frequency for this country.
Please post pictures (front and back) of these bad boys.
Thanks Mike. Yep, I think you nailed it. They are not on the US frequency, so not heard by the ST.
Now, removing these from the walls will be a fun task… :wink:
Sorry dude. Hopefully you didn’t get soaked on the deal.
