I had a few SmartThings ADT Water Leak Detectors working perfectly fine during the pre-Edge driver days. A few months ago, Samsung ‘accidentally’ deleted all my devices, and I couldn’t add them back without a factory reset. I am slowly adding all my devices back. Today I successfully re-added the water sensors. They show up under my devices and work as expected, showing Dry/Wet status, temperature, and battery. But sensors are not showing up under Home Monitor. When I go to Life > Home Monitor > Leaks, it says ‘no Leak sensor.’ Is anyone having the same issue?
