Hi all!
Fairly new to the community and only been using ST a short while now but like the potential of a smart home.
Because of recent water events at my home I’ve installed several water sensors. A couple different kinds (including the ADT sensors), suddenly they all went offline within the last week sometime.
This seems to be something that’s been noted by the community for years with no real explanation and few workarounds besides removing and re-adding the devices. So, unfortunately I decided to do that but also noticed my automations related to my water sensors was gone!
So, I set my automation up again (which notifies me via text and sounds an alarm). I then dropped and re-added one of the water sensors, which took fine, but when I went to check the automation to ensure it was still in the list, the automation was gone again!
A bug when you remove a sensor in an automation? Dunno, maybe.
So, a couple questions hoping folks can help me out:
- Is there a way to keep the sensors from going off line? If not, is there a way to easily add them back in?
- Is there a way to ensure your automations don’t disappear when dropping devices?
I’m using the 3rd Gen ST Hub with ADT Water Leak Sensors, and the my ST app is v1.7.51.42 which I plan to update soon.
Thanks in advance guys!
Chuck
