Normally, I can pretty much find whatever I need so I apologize if this is not correctly entered.
I am looking for another Smart App that mimics the leak detector in the Smart Home Monitor, which I love. I also posted the question to support as maybe a feature request for the SMH in the custom section. It seems that Samsung could easily fix this by adding moisture sensors on their custom portion of the SMH, but have not for some reason.
I recently just had a leak detector set up on my water heater with a sensor near it so if a leak was detected, it would close off the water valve supplying it, shut off its power (it is a gas water heater but shutting off the power keeps it from coming on), turns on the lights in the area, texts me, and then turns the hall light I have a specific color to indicate a problem.
I now have Dome water valve controllers controlling each floorâs water supply, hot or cold with various sensors under sinks, the dishwasher, etc. I wanted to do the same thing with the water heater but more custom tuned to that device if water was detected.
The SMH leak app is an all or nothing app meaning I really think it was designed to shut off the main water if an number of leak sensors go off. In most homes, that may not be necessary, depending on the leak.
For instance, if the dishwasher springs a leak, shut off the hot water to the main floor that supplies the kitchen, and do the text, and lights. If the refrigerator springs a leak, shut off the cold water to the main floor, text and do the affected lights. If the bathroom sink springs a leak, shut off both hot and cold water supplying that bathroomâs floor, text, lights, etc.
Does anyone know if a SmartApp has been created that mimics the SMH leak app so I can have separate leak actions based on what sensor goes off?
