3rd Party Hubs not connecting - work around
I want to start this with a thanks to @diehllane for pointing me in the right direction to get this fixed.
Also thanks to @jjslegacy for coming up with the fix.
I’m just passing on the info. @chrisjohnson00 this is what you need.
This is works wonderfully for my Phillips Hue Hub. I have no idea about any others, but this should work for them as well.
In the Phillips Hue connect app (if you still have it installed and you’re getting the “Hub needs updating” warning, do this:
Change Line 696-699 (in the code below) to look like this:
private Boolean canInstallLabs() {
//return hasAllHubsOver(“000.011.00603”)
return true
If you have uninstalled the app for whatever reason, Here is the modified code. Just go into the API and create a new smartapp from code. Use this code:
  • Hue Service Manager
  • Author: Juan Risso (juan@smartthings.com)
  • Copyright 2015 SmartThings
  • Licensed under the Apache License, Version 2.0 (the “License”); you may not use this file except
  • in compliance with the License. You may obtain a copy of the License at:
  •  http://www.apache.org/licenses/LICENSE-2.0
  • Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
  • on an “AS IS” BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
  • for the specific language governing permissions and limitations under the License.
definition(
name: “Hue (Connect)”,
namespace: “smartthings”,
author: “SmartThings”,
description: “Allows you to connect your Philips Hue lights with SmartThings and control them from your Things area or Dashboard in the SmartThings Mobile app. Adjust colors by going to the Thing detail screen for your Hue lights (tap the gear on Hue tiles).\n\nPlease update your Hue Bridge first, outside of the SmartThings app, using the Philips Hue app.”,
category: “SmartThings Labs”,
iconUrl: “https://s3.amazonaws.com/smartapp-icons/Partner/hue.png”,
iconX2Url: “https://s3.amazonaws.com/smartapp-icons/Partner/hue@2x.png”,
singleInstance: true
preferences {
page(name:“mainPage”, title:“Hue Device Setup”, content:“mainPage”, refreshTimeout:5)
page(name:“bridgeDiscovery”, title:“Hue Bridge Discovery”, content:“bridgeDiscovery”, refreshTimeout:5)
page(name:“bridgeBtnPush”, title:“Linking with your Hue”, content:“bridgeLinking”, refreshTimeout:5)
page(name:“bulbDiscovery”, title:“Hue Device Setup”, content:“bulbDiscovery”, refreshTimeout:5)
def mainPage() {
if(canInstallLabs()) {
def bridges = bridgesDiscovered()
if (state.username && bridges) {
return bulbDiscovery()
} else {
return bridgeDiscovery()
} else {
def upgradeNeeded = “”“To use SmartThings Labs, your Hub should be completely up to date.
To update your Hub, access Location Settings in the Main Menu (tap the gear next to your location name), select your Hub, and choose “Update Hub”.”"“
return dynamicPage(name:“bridgeDiscovery”, title:“Upgrade needed!”, nextPage:”", install:false, uninstall: true) {
section(“Upgrade”) {
paragraph “$upgradeNeeded”
def bridgeDiscovery(params=[:])
int bridgeRefreshCount = !state.bridgeRefreshCount ? 0 : state.bridgeRefreshCount as int
state.bridgeRefreshCount = bridgeRefreshCount + 1
def refreshInterval = 3
def options = bridges ?: []
def numFound = options.size() ?: 0
if (numFound == 0 && state.bridgeRefreshCount > 25) {
log.trace "Cleaning old bridges memory"
state.bridges = [:]
state.bridgeRefreshCount = 0
app.updateSetting(“selectedHue”, “”)
subscribe(location, null, locationHandler, [filterEvents:false])
//bridge discovery request every 15 //25 seconds
if((bridgeRefreshCount % 5) == 0) {
discoverBridges()
//setup.xml request every 3 seconds except on discoveries
if(((bridgeRefreshCount % 1) == 0) && ((bridgeRefreshCount % 5) != 0)) {
verifyHueBridges()
return dynamicPage(name:“bridgeDiscovery”, title:“Discovery Started!”, nextPage:“bridgeBtnPush”, refreshInterval:refreshInterval, uninstall: true) {
section(“Please wait while we discover your Hue Bridge. Discovery can take five minutes or more, so sit back and relax! Select your device below once discovered.”) {
input “selectedHue”, “enum”, required:false, title:“Select Hue Bridge (${numFound} found)”, multiple:false, options:options
def bridgeLinking()
int linkRefreshcount = !state.linkRefreshcount ? 0 : state.linkRefreshcount as int
state.linkRefreshcount = linkRefreshcount + 1
def nextPage = ""
def title = "Linking with your Hue"
def paragraphText
def hueimage = null
if (selectedHue) {
paragraphText = "Press the button on your Hue Bridge to setup a link. "
hueimage = “http://huedisco.mediavibe.nl/wp-content/uploads/2013/09/pair-bridge.png”
} else {
paragraphText = “You haven’t selected a Hue Bridge, please Press “Done” and select one before clicking next.“
hueimage = null
if (state.username) { //if discovery worked
nextPage = “bulbDiscovery"
title = “Success!“
paragraphText = “Linking to your hub was a success! Please click ‘Next’!“
hueimage = null
if((linkRefreshcount % 2) == 0 && !state.username) {
sendDeveloperReq()
return dynamicPage(name:“bridgeBtnPush”, title:title, nextPage:nextPage, refreshInterval:refreshInterval) {
section(””) {
paragraph “””${paragraphText}””“
if (hueimage != null)
image “${hueimage}”
def bulbDiscovery() {
int bulbRefreshCount = !state.bulbRefreshCount ? 0 : state.bulbRefreshCount as int
state.bulbRefreshCount = bulbRefreshCount + 1
state.inBulbDiscovery = true
def bridge = null
if (selectedHue) {
bridge = getChildDevice(selectedHue)
subscribe(bridge, “bulbList”, bulbListData)
def bulboptions = bulbsDiscovered() ?: [:]
def numFound = bulboptions.size() ?: 0
if (numFound == 0)
app.updateSetting(“selectedBulbs”, “”)
if((bulbRefreshCount % 5) == 0) {
discoverHueBulbs()
return dynamicPage(name:“bulbDiscovery”, title:“Bulb Discovery Started!”, nextPage:””, refreshInterval:refreshInterval, install:true, uninstall: true) {
section(“Please wait while we discover your Hue Bulbs. Discovery can take five minutes or more, so sit back and relax! Select your device below once discovered.”) {
input “selectedBulbs”, “enum”, required:false, title:“Select Hue Bulbs (${numFound} found)”, multiple:true, options:bulboptions
section {
def title = getBridgeIP() ? “Hue bridge (${getBridgeIP()})” : “Find bridges"
href “bridgeDiscovery”, title: title, description: “”, state: selectedHue ? “complete” : “incomplete”, params: [override: true]
private discoverBridges() {
sendHubCommand(new physicalgraph.device.HubAction(“lan discovery urn:schemas-upnp-org:device:basic:1”, physicalgraph.device.Protocol.LAN))
private sendDeveloperReq() {
def token = app.id
def host = getBridgeIP()
sendHubCommand(new physicalgraph.device.HubAction([
method: “POST”,
path: “/api”,
headers: [
HOST: host
body: [devicetype: “$token-0”, username: “$token-0”]], “${selectedHue}”))
private discoverHueBulbs() {
method: “GET”,
path: “/api/${state.username}/lights”,
headers: [
HOST: host
private verifyHueBridge(String deviceNetworkId, String host) {
method: “GET”,
path: “/description.xml”,
headers: [
HOST: host
]], deviceNetworkId))
private verifyHueBridges() {
def devices = getHueBridges().findAll { it?.value?.verified != true }
devices.each {
def ip = convertHexToIP(it.value.networkAddress)
def port = convertHexToInt(it.value.deviceAddress)
verifyHueBridge(”${it.value.mac}”, (ip + “:” + port))
Map bridgesDiscovered() {
def vbridges = getVerifiedHueBridges()
def map = [:]
vbridges.each {
def value = “${it.value.name}“
def key = “${it.value.mac}“
map[”${key}”] = value
map
Map bulbsDiscovered() {
def bulbs = getHueBulbs()
def bulbmap = [:]
if (bulbs instanceof java.util.Map) {
bulbs.each {
def key = app.id +”/”+ it.value.id
bulbmap[”${key}”] = value
} else { //backwards compatable
bulbs.each {
def value = “${it.name}“
def key = app.id +”/”+ it.id
logg += “$value - $key, “
return bulbmap
def bulbListData(evt) {
state.bulbs = evt.jsonData
Map getHueBulbs() {
state.bulbs = state.bulbs ?: [:]
def getHueBridges() {
state.bridges = state.bridges ?: [:]
def getVerifiedHueBridges() {
getHueBridges().findAll{ it?.value?.verified == true }
def installed() {
log.trace "Installed with settings: ${settings}"
initialize()
def updated() {
log.trace "Updated with settings: ${settings}"
unschedule()
unsubscribe()
initialize()
def initialize() {
log.debug "Initializing"
unsubscribe(bridge)
state.inBulbDiscovery = false
state.bulbRefreshCount = 0
if (selectedHue) {
addBridge()
addBulbs()
doDeviceSync()
runEvery5Minutes(“doDeviceSync”)
def manualRefresh() {
unschedule()
unsubscribe()
doDeviceSync()
def uninstalled(){
state.bridges = [:]
state.username = null
// Handles events to add new bulbs
def bulbListHandler(hub, data = “”) {
def msg = "Bulbs list not processed. Only while in settings menu."
def bulbs = [:]
if (state.inBulbDiscovery) {
def logg = ""
log.trace "Adding bulbs to state…"
state.bridgeProcessedLightList = true
def object = new groovy.json.JsonSlurper().parseText(data)
object.each { k,v ->
if (v instanceof Map)
bulbs[k] = [id: k, name: v.name, type: v.type, hub:hub]
def bridge = null
if (selectedHue)
bridge.sendEvent(name: “bulbList”, value: hub, data: bulbs, isStateChange: true, displayed: false)
msg = "${bulbs.size()} bulbs found. ${bulbs}"
return msg
def addBulbs() {
selectedBulbs?.each { dni ->
def d = getChildDevice(dni)
if(!d) {
def newHueBulb
newHueBulb = bulbs.find { (app.id + “/” + it.value.id) == dni }
if (newHueBulb != null) {
if (newHueBulb?.value?.type?.equalsIgnoreCase(“Dimmable light”) ) {
d = addChildDevice(“smartthings”, “Hue Lux Bulb”, dni, newHueBulb?.value.hub, [“label”:newHueBulb?.value.name])
} else {
d = addChildDevice(“smartthings”, “Hue Bulb”, dni, newHueBulb?.value.hub, [“label”:newHueBulb?.value.name])
} else {
log.debug “$dni in not longer paired to the Hue Bridge or ID changed”
} else {
newHueBulb = bulbs.find { (app.id + “/” + it.id) == dni }
d = addChildDevice(“smartthings”, “Hue Bulb”, dni, newHueBulb?.hub, [“label”:newHueBulb?.name])
log.debug "created ${d.displayName} with id $dni"
d.refresh()
} else {
log.debug “found ${d.displayName} with id $dni already exists, type: ‘$d.typeName’“
def newHueBulb = bulbs.find { (app.id + “/” + it.value.id) == dni }
if (newHueBulb?.value?.type?.equalsIgnoreCase(“Dimmable light”) && d.typeName == “Hue Bulb”) {
d.setDeviceType(“Hue Lux Bulb”)
def addBridge() {
def vbridge = vbridges.find {”${it.value.mac}” == selectedHue}
if(vbridge) {
def d = getChildDevice(selectedHue)
if(!d) {
// compatibility with old devices
def newbridge = true
childDevices.each {
if (it.getDeviceDataByName(“mac”)) {
def newDNI = "${it.getDeviceDataByName(“mac”)}"
if (newDNI != it.deviceNetworkId) {
def oldDNI = it.deviceNetworkId
log.debug “updating dni for device ${it} with $newDNI - previous DNI = ${it.deviceNetworkId}“
it.setDeviceNetworkId(”${newDNI}”)
if (oldDNI == selectedHue)
app.updateSetting(“selectedHue”, newDNI)
newbridge = false
if (newbridge) {
d = addChildDevice(“smartthings”, “Hue Bridge”, selectedHue, vbridge.value.hub)
log.debug “created ${d.displayName} with id ${d.deviceNetworkId}“
def childDevice = getChildDevice(d.deviceNetworkId)
childDevice.sendEvent(name: “serialNumber”, value: vbridge.value.serialNumber)
if (vbridge.value.ip && vbridge.value.port) {
if (vbridge.value.ip.contains(”.”)) {
childDevice.sendEvent(name: “networkAddress”, value: vbridge.value.ip + “:” + vbridge.value.port)
childDevice.updateDataValue(“networkAddress”, vbridge.value.ip + “:” + vbridge.value.port)
} else {
childDevice.sendEvent(name: “networkAddress”, value: convertHexToIP(vbridge.value.ip) + “:” + convertHexToInt(vbridge.value.port))
childDevice.updateDataValue(“networkAddress”, convertHexToIP(vbridge.value.ip) + “:” + convertHexToInt(vbridge.value.port))
} else {
childDevice.sendEvent(name: “networkAddress”, value: convertHexToIP(vbridge.value.networkAddress) + “:” + convertHexToInt(vbridge.value.deviceAddress))
childDevice.updateDataValue(“networkAddress”, convertHexToIP(vbridge.value.networkAddress) + “:” + convertHexToInt(vbridge.value.deviceAddress))
} else {
log.debug “found ${d.displayName} with id $selectedHue already exists”
def locationHandler(evt) {
def description = evt.description
log.trace “Location: $description"
def hub = evt?.hubId
def parsedEvent = parseLanMessage(description)
parsedEvent << [“hub”:hub]
if (parsedEvent?.ssdpTerm?.contains(“urn:schemas-upnp-org:device:basic:1”)) {
//SSDP DISCOVERY EVENTS
log.trace “SSDP DISCOVERY EVENTS"
def bridges = getHueBridges()
log.trace bridges.toString()
if (!(bridges.”${parsedEvent.ssdpUSN.toString()}”)) {
//bridge does not exist
log.trace “Adding bridge ${parsedEvent.ssdpUSN}“
bridges << [”${parsedEvent.ssdpUSN.toString()}”:parsedEvent]
} else {
// update the values
def ip = convertHexToIP(parsedEvent.networkAddress)
def port = convertHexToInt(parsedEvent.deviceAddress)
def host = ip + “:” + port
log.debug "Device ($parsedEvent.mac) was already found in state with ip = $host.“
def dstate = bridges.”${parsedEvent.ssdpUSN.toString()}"
def dni = "${parsedEvent.mac}"
def networkAddress = null
if (!d) {
childDevices.each {
doDeviceSync()
} else {
if (d.getDeviceDataByName(“networkAddress”))
networkAddress = d.getDeviceDataByName(“networkAddress”)
else
networkAddress = d.latestState(‘networkAddress’).stringValue
log.trace "Host: $host - $networkAddress"
if(host != networkAddress) {
log.debug "Device’s port or ip changed for device $d…"
dstate.ip = ip
dstate.port = port
dstate.name = "Philips hue ($ip)"
d.sendEvent(name:“networkAddress”, value: host)
d.updateDataValue(“networkAddress”, host)
else if (parsedEvent.headers && parsedEvent.body) {
log.trace "HUE BRIDGE RESPONSES"
def headerString = parsedEvent.headers.toString()
if (headerString?.contains(“xml”)) {
log.trace "description.xml response (application/xml)"
def body = new XmlSlurper().parseText(parsedEvent.body)
if (body?.device?.modelName?.text().startsWith(“Philips hue bridge”)) {
def bridge = bridges.find {it?.key?.contains(body?.device?.UDN?.text())}
if (bridge) {
bridge.value << [name:body?.device?.friendlyName?.text(), serialNumber:body?.device?.serialNumber?.text(), verified: true]
} else {
log.error “/description.xml returned a bridge that didn’t exist”
} else if(headerString?.contains(“json”)) {
log.trace "description.xml response (application/json)"
def body = new groovy.json.JsonSlurper().parseText(parsedEvent.body)
if (body.success != null) {
if (body.success[0] != null) {
if (body.success[0].username)
state.username = body.success[0].username
} else if (body.error != null) {
//TODO: handle retries…
log.error “ERROR: application/json ${body.error}”
} else {
//GET /api/${state.username}/lights response (application/json)
if (!body?.state?.on) { //check if first time poll made it here by mistake
log.debug "Adding bulbs to state!"
body.each { k,v ->
bulbs[k] = [id: k, name: v.name, type: v.type, hub:parsedEvent.hub]
} else {
log.trace “NON-HUE EVENT $evt.description”
def doDeviceSync(){
log.trace "Doing Hue Device Sync!"
convertBulbListToMap()
poll()
try {
} catch (all) {
log.trace “Subscription already exist”
discoverBridges()
//CHILD DEVICE METHODS
def parse(childDevice, description) {
def bodyString = parsedEvent.body.toString()
if (headerString?.contains(“json”)) {
def body
try {
body = new groovy.json.JsonSlurper().parseText(bodyString)
} catch (all) {
log.warn “Parsing Body failed - trying again…“
poll()
if (body instanceof java.util.HashMap) {
//poll response
def bulbs = getChildDevices()
for (bulb in body) {
def d = bulbs.find{it.deviceNetworkId == “${app.id}/${bulb.key}”}
if (d) {
if (bulb.value.state?.reachable) {
sendEvent(d.deviceNetworkId, [name: “switch”, value: bulb.value?.state?.on ? “on” : “off”])
sendEvent(d.deviceNetworkId, [name: “level”, value: Math.round(bulb.value.state.bri * 100 / 255)])
if (bulb.value.state.sat) {
def hue = Math.min(Math.round(bulb.value.state.hue * 100 / 65535), 65535) as int
def sat = Math.round(bulb.value.state.sat * 100 / 255) as int
def hex = colorUtil.hslToHex(hue, sat)
sendEvent(d.deviceNetworkId, [name: “color”, value: hex])
sendEvent(d.deviceNetworkId, [name: “hue”, value: hue])
sendEvent(d.deviceNetworkId, [name: “saturation”, value: sat])
} else {
sendEvent(d.deviceNetworkId, [name: “switch”, value: “off”])
sendEvent(d.deviceNetworkId, [name: “level”, value: 100])
def hue = 23
def sat = 56
def hex = colorUtil.hslToHex(23, 56)
else
{ //put response
def hsl = [:]
body.each { payload ->
log.debug $payload
if (payload?.success)
def childDeviceNetworkId = app.id + “/“
def eventType
body?.success[0].each { k,v ->
childDeviceNetworkId += k.split(”/”)[2]
if (!hsl[childDeviceNetworkId]) hsl[childDeviceNetworkId] = [:]
eventType = k.split(”/”)[4]
log.debug "eventType: $eventType"
switch(eventType) {
case “on”:
sendEvent(childDeviceNetworkId, [name: “switch”, value: (v == true) ? “on” : “off”])
break
case “bri”:
sendEvent(childDeviceNetworkId, [name: “level”, value: Math.round(v * 100 / 255)])
break
case “sat”:
hsl[childDeviceNetworkId].saturation = Math.round(v * 100 / 255) as int
break
case “hue”:
hsl[childDeviceNetworkId].hue = Math.min(Math.round(v * 100 / 65535), 65535) as int
break
else if (payload.error)
log.debug “JSON error - ${body?.error}”
hsl.each { childDeviceNetworkId, hueSat ->
if (hueSat.hue && hueSat.saturation) {
def hex = colorUtil.hslToHex(hueSat.hue, hueSat.saturation)
log.debug "sending ${hueSat} for ${childDeviceNetworkId} as ${hex}"
sendEvent(hsl.childDeviceNetworkId, [name: “color”, value: hex])
} else {
log.debug "parse - got something other than headers,body…"
return []
def on(childDevice) {
log.debug "Executing ‘on’"
put(“lights/${getId(childDevice)}/state”, [on: true])
return “Bulb is On”
def off(childDevice) {
log.debug "Executing ‘off’"
put(“lights/${getId(childDevice)}/state”, [on: false])
return “Bulb is Off”
def setLevel(childDevice, percent) {
log.debug "Executing ‘setLevel’"
def level
if (percent == 1) level = 1 else level = Math.min(Math.round(percent * 255 / 100), 255)
put(“lights/${getId(childDevice)}/state”, [bri: level, on: percent > 0])
def setSaturation(childDevice, percent) {
log.debug "Executing ‘setSaturation($percent)’"
def level = Math.min(Math.round(percent * 255 / 100), 255)
put(“lights/${getId(childDevice)}/state”, [sat: level])
def setHue(childDevice, percent) {
log.debug “Executing ‘setHue($percent)’“
def level = Math.min(Math.round(percent * 65535 / 100), 65535)
put(“lights/${getId(childDevice)}/state”, [hue: level])
def setColor(childDevice, huesettings) {
log.debug “Executing ‘setColor($huesettings)’“
def hue = Math.min(Math.round(huesettings.hue * 65535 / 100), 65535)
def sat = Math.min(Math.round(huesettings.saturation * 255 / 100), 255)
def alert = huesettings.alert ? huesettings.alert : “none"
def transition = huesettings.transition ? huesettings.transition : 4
def value = [sat: sat, hue: hue, alert: alert, transitiontime: transition]
if (huesettings.level != null) {
if (huesettings.level == 1) value.bri = 1 else value.bri = Math.min(Math.round(huesettings.level * 255 / 100), 255)
value.on = value.bri > 0
if (huesettings.switch) {
value.on = huesettings.switch == “on”
log.debug “sending command $value"
put(“lights/${getId(childDevice)}/state”, value)
def nextLevel(childDevice) {
def level = device.latestValue(“level”) as Integer ?: 0
if (level < 100) {
level = Math.min(25 * (Math.round(level / 25) + 1), 100) as Integer
else {
level = 25
setLevel(childDevice,level)
private getId(childDevice) {
if (childDevice.device?.deviceNetworkId?.startsWith(“HUE”)) {
return childDevice.device?.deviceNetworkId[3…-1]
else {
return childDevice.device?.deviceNetworkId.split(”/”)[-1]
private poll() {
def uri = “/api/${state.username}/lights/“
try {
sendHubCommand(new physicalgraph.device.HubAction(””“GET ${uri} HTTP/1.1
HOST: ${host}
”””, physicalgraph.device.Protocol.LAN, selectedHue))
} catch (all) {
doDeviceSync()
private put(path, body) {
def uri = “/api/${state.username}/$path"
def bodyJSON = new groovy.json.JsonBuilder(body).toString()
def length = bodyJSON.getBytes().size().toString()
log.debug “PUT: $host$uri"
log.debug “BODY: ${bodyJSON}“
sendHubCommand(new physicalgraph.device.HubAction(””“PUT $uri HTTP/1.1
HOST: ${host}
Content-Length: ${length}
${bodyJSON}
”””, physicalgraph.device.Protocol.LAN, “${selectedHue}”))
private getBridgeIP() {
def host = null
if (selectedHue) {
if (d) {
host = d.getDeviceDataByName(“networkAddress”)
else
host = d.latestState(‘networkAddress’).stringValue
if (host == null || host == “”) {
def serialNumber = selectedHue
def bridge = getHueBridges().find { it?.value?.serialNumber?.equalsIgnoreCase(serialNumber) }?.value
if (!bridge) {
bridge = getHueBridges().find { it?.value?.mac?.equalsIgnoreCase(serialNumber) }?.value
if (bridge?.ip && bridge?.port) {
if (bridge?.ip.contains(”.”))
host = “${bridge?.ip}:${bridge?.port}“
else
host = “${convertHexToIP(bridge?.ip)}:${convertHexToInt(bridge?.port)}”
} else if (bridge?.networkAddress && bridge?.deviceAddress)
host = “${convertHexToIP(bridge?.networkAddress)}:${convertHexToInt(bridge?.deviceAddress)}”
log.trace “Bridge: $selectedHue - Host: $host”
return host
private Integer convertHexToInt(hex) {
Integer.parseInt(hex,16)
def convertBulbListToMap() {
try {
if (state.bulbs instanceof java.util.List) {
def map = [:]
state.bulbs.unique {it.id}.each { bulb ->
map << [”${bulb.id}”:[“id”:bulb.id, “name”:bulb.name, “hub”:bulb.hub]]
state.bulbs = map
catch(Exception e) {
log.error “Caught error attempting to convert bulb list to map: $e”
private String convertHexToIP(hex) {
[convertHexToInt(hex[0…1]),convertHexToInt(hex[2…3]),convertHexToInt(hex[4…5]),convertHexToInt(hex[6…7])].join(”.”)
return true
private Boolean hasAllHubsOver(String desiredFirmware) {
return realHubFirmwareVersions.every { fw -> fw >= desiredFirmware }
private List getRealHubFirmwareVersions() {
return location.hubs
.firmwareVersionString.findAll { it }
I used this for @joshua_lyon’s Kodi app, as well, which is where I found the original post from @jjslegacy.
I would assume it works with any SmartThings Lab item from Harmony to Sonos and everything in between.
If you know someone who has the working app, ask them to PM it over to you and then install it from the IDE as copy/paste code, editing the lines as needed to force your hub into compatibility.
I did receive an update from ST support on this today actually. They admitted they were a little premature in the last update stating the hasAllHubsOver issue was resolved.
I sincerely apologize for the confusion - We were a little too eager in letting our users know that this issue had been fixed, but later found out that this wasn’t actually the case. We understand this is ongoing and are continuing to look into it.
We will follow up again once resolved. Again, very sorry about the mixup!
Just tried this for both the wemo connect and the hue app. But its not finding any of my switches or my hub for the hue. So while I passed the fw check it doesn’t seem to actually be working.
@sojhinn
give it time for the hue hub… i usually back out and go back into the app several times before it’s found.
I don’t know about the Wemo stuff. sorry.
I’m starting to think something is majorly wrong with my hub… Ive had it running for several minutes already.
What I’ve always done is open the app and click on the Hue Bridge part… it opens and does not show a hub, then I back out. I go in and out several times and this usually works just fine.
Yeah thats what I used to do too. It was working fine three days ago, I removed the hue hub and my wemo switches due to polling issues. And I haven’t been able to get them back since. But I feel like I’m getting this topic off topic. Thanks for trying to help.
I don’t think it’s off topic. I started to help others get their hubs back integrated.
Have you tried resetting the hue hub? Have you rebooted the ST and tried to install the app then?
Rebooted the ST before hand but currently trying rebooting the hue hub. What worries me is the fact the wemo switches are not being found either.
Edit: No luck so far.
@bamarayne
Is it worth it for me to jump over to a v2?
I wish I could give a straight answer on that, but I never used the V1 Hub.
But, in my opinion, with the way that ST is aggressively branching out into new things (Samsung TV’s) I do not think any support of the V1 is going to happen. Actually, I’m pretty sure it’s done as there hasn’t been a V1 update since the V2 release.
Other than that, I don’t know a good reason to upgrade. Other than it’s new hardware in the tech which quite often realizes into better performance.
Not sure if it has to do with local vs other control; since I’m using the v1 hub.
Well, the only local on the V2 hub is the Smart Lighting app and parts of SHM, and ONLY if you are using devices on the supported list AND the ST device handlers.
I have exactly 2 smart Lighting rules running local. Everything else is cloud.
I got this partially working on my Hue and Wemos. It will only add the bloom though. When I try to add the white only bulbs it says an unexpected error occurred. With the Wemos I was able to add all my switches but when I tried adding the insight outlet it also said an unexpected error occurred. Any ideas? At least I am getting some stuff so thanks for that!
Sorry, not a clue. I installed a fresh copy of the code via the api and it worked flawlessly for me. I installed the hue bridge - version one, two version one white lux bulbs, two version two white lux bulbs, and two version one color hue bulbs.
I haven’t had a glitch out of it.
I haven’t tried the wemo stuff because I took all of my wemo stuff and put it in a box.
I’m at wit’s end with trying to re-discover my hue bridge. Thanks for this method, but it doesn’t seem to work either for me. ST v1, Hue v2. I had my hue lights connected to ST and operating fine for almost a week until I decided to reorganize the way I was doing things. I removed all things hue and now I can’t add them back. Any other thoughts of what the problem might be? Regards.
I created the smart app using your code. After I connect to the HUe hub and lights, I hit done. The I get the following in the live log.
4:49:37 PM: error physicalgraph.app.exception.UnknownDeviceTypeException: Device type ‘Hue Bridge’ in namespace ‘smartthings’ not found. @ line 333
This worked for me fixing the media renderer app… thanks for getting that info out there.
Add a Device Handler for the Hue Bridge and publish to yourself.
From the developers under "My Device Handlers, select “Create New Device Handler.” and then choose Hue Bridge from the templates. You shouldn’t need to make any changes.
So hopefully you just need to add the device handler to your account and you’re back in business. It worked for me with my Bose SoundTouch speaker. I was getting the same error as you.
Good Luck.
I am trying to add a 3rd party Hue Bridge, (a Raspberry Pi with Hue Bridge Emulator), to my Smartthings Hub. In the logs, it keeps saying “/description.xml returned a bridge that didn’t exist”. Anyone has any clue on how to fix this?
Thanks.
