I am trying to bring back to use several ZXT-120s I had previously used some years ago with SmartThings Classic and Gouldner’s Device Handler.
Since there was a lot of mention of RBoys Device Handler I decided to buy such code to avoid and incompatibilities with the new SmartThings.
Turns out that even though SmartThings and the ZXT-120s are communicating well as I can see the LED light blink when the Off/Cool setting is toggled, and I am not able to control my split unit a/c’s with the remote code I previously used. I also tried all remote codes for Fujitsu to no avail.
At the moment I am unsure if the ZXT-120 is receiving the correct IR remote code.
I also had problems obtaining the right IR code. I increased and decreased numbers eventually found in my case that 399 is not working and 401 is working.
I also used IR analyzer to compare the sent ZXT-120 code and my Remote code, which showed clearly when to sent ZXT-120 IR command is the same as the Remote IR command.
as explained here: http://www.ostan.cz/IR_protocol_analyzer/
MUST SAY THAT REMOTEC SUPPORT IS TERRIBLE AND THEY NEVER ANSWER
RBoy
23
