Does this sensor work out of the box with smartthings or should I use a custom device handler? If I’m correct when using a custom device handler makes it cloud dependent… not sure.
Dom
It will work without the DH, but I don’t recall if it operated locally without it. I’m presently running under the DH and it is cloud execution now. You lose a lot of settings without the DH. I was experiencing a lot of false positive motion reports and needed to adjust the sensitivity. Needed the DH for that.
