Hi,
Good day ahead and hope you are doing well. Can anyone help me how to use a normal Zigbee switch to a virtual momentary switch so that i can use it for the garage door.
Hi,
Hi Rizwan, welcome to the forums! Virtual switches can be really helpful in home automation. Could you elaborate a bit more on your particular setup? For instance, is the zigbee on/off switch connected your garage door right now?
Iam looking for a device handler which should work as a momentary switch.
Normal Zigbee switch should work as Virtual momentary switch. If you have a device handler then please send me.
So, typically Virtual Devices are separate from real-world devices. Often people will make rules that turn on/off a real switch when a virtual switch is pressed. Check out
this may be what you’re after.
