HI,
I got a Nue 3 Gang & 2 Gang Smart switch. I want to allocate Switch 1 to Room 1, Switch 2 to Room 2 and Switch 3 to Room 3 but under devices they all just show up as 1 switch and i can only allocate to 1 room. How can i split the 3 gang or 2 gang into individual devices?
Thanks,
Raman
rontalley
(Ron Talley)
June 30, 2018, 1:46pm
2
See if this works:
[image]
Update: Here is a great step by step on how use this SmartApp with multi-relay devices. It was written with the Enerwave RSM2 Dual Relay Switch in mind, but most of it is applicable to other devices as well. Thanks @Mike_Rolle
This is really just an upgraded version of my Virtual / Physical Switch Sync SmartApp. SmartThings currently doesn’t support using anything other than the first switch in a multi-switch (multi-channel) device in automations, routines, etc. This SmartApp solves that problem. It creates virtual devices for each endpoint, and keeps them in sync with what the real device is doing. This app improves on my other app in these ways:
It creates the virtual devices for you. This greatly speeds up the process.
It allows you to use a few different types of switches. …
If not then you have this thread:
I need some help with creating a DH for this product: http://3asmarthome.com/zigbee-smart-dimmer-switch
It’s a 3 gang light switch. No dimmers (despite the link above).
I have the device paired with ST. I’ve been using this DH for a week or so: KUDLED - UK 1/2/3 Gang Switch
I can turn all three lights on and off via the ST app. However, if I turn turn the actual light switch on, it is NOT updated in the ST app. I’m not sure how to figure out the inclusters and outclusters. The endpoints are 13, 12 and 11. I’m using 3 virtual switches (simulated) and binded the 3 switches to the 3 virtual light switches using the kudled smart app above.
I have re-paired the device to get the catchall, and these are below.
Catchall
zbjoin: {“dni”:“BF8A”,“d”:“00124B000CB562D2”,“capabilities”:“8E”,“endpo…
@rontalley , Thanks for the tip. I got the Virtual switch working with the 2 gangs switch following the instructions. It created the 2 virtual switches but only 1 work and the other does not. Also, when i applied the same DH for the 3 gang it did not create the 3 virtual switches.
Have you checked out the Support page https://3asmarthome.com/downloads which has links to DH for the various products?
