Zigbee Mesh Issues
I have a pretty extensive SmartThings network at home and am running into some Zigbee connectivity issues. I used to have a ThirdReality Multi-Function Night Light Zigbee Repeater in my basement bathroom but it would cause problems from time to time so I have unplugged it and removed it from SmartThings. Any time someone would unplug the device I would lose connectivity with most of the Zigbee devices in my home and wouldn’t be able to get them reconnected without resetting each individual device. It would also routinely drop connectivity to my hub and cause the same issues without ever being unplugged.
From looking at the SmartThings app most of the Zigbee devices that would need resetting connected to my hub through the Night Light and wouldn’t re route no matter how many times they or my main hub was restarted. After removing the Night Light from the system, power cycling my hub multiple times, and reinstalling batteries I’m still having issues reconnecting a bunch of Zigbee devices. The devices include 2x Ikea Fyutur blinds, multiple Sonoff and ThirdReality temperature/humidity sensors, a ThirdReality Motion Sensor, an Alibaba blinds motor, a Sonoff Motion Sensor, a Sengled smart plug, and a ThirdReality leak sensor.
I tried to reset one of the Sonoff temperature sensors and one of the ThirdReality temperature sensors to reconnect them but haven’t had success reconnecting either. A little worried to try it out on more sensors as I don’t want to rebuild my whole network unless I have to. Any ideas? I’ve already removed and reinstalled batteries in all the various sensors, will be recharging/replacing them moving forward and seeing if that helps. Some of them show a “missing device” between them and the hub when you view the connection path whereas others just show them disconnected from the hub with nothing in between.
Try powering the hub off for at least 20 minutes.
Try to separate as far as possible between wifi Router (or wifi Mesh Antenna) and your SmartThings Hub. I found that the interfering of Wi-Fi can easily damage the reception of Zigbee signals.
