Arn: could you please explain how to find, install and publish those two modules. Thanks for the help.
The linked release notice has the information you need. Should you not be using the IDEâs github facility, the release notice includes links to the raw files for manual update
Weâve disabled the change that caused the Keypads to stop working and will investigate better error handling options to prevent it from happening again. That being said it would be a good idea to update to the latest code that @arnb posted.
Arn: I have updated the device handler for the keypad via the raw files for manual update that you provided, but my IRIS keypad V2 is still not working properly. I do not use SHM Delay APP because I do not use the delay function when arming / disarming using the keypad. There is no need to have delay as my keypad is in the garage. I only use the device handler and ethrayerâs Lock Manager for User PIN.
I tried, deleting the Keypad from the Smart App and re-pairing the keypad, as well. I also deleted the original Mitchpond Device Handler and added the updated file for the keypad device handler, too. I am not sure what I am doing wrong. I have no trouble arming / disarming using the Smarthing APP on my phone but the keypad is to no avail.
This is the link file that I used for the keypad device handler:
Can you please provide some guidance? Thank you!
- Provide warning to the community a few weeks in advance of the change.
- Modify the Save, compile phase to throw an error when the data appears wrong
- Throw an error when an error is caught, rather that tossing the command into the ozone
Regarding the code reversion: Perhaps it will help some, and confuse others, who knows. Those of us who were severely impacted have moved on.
The updated DTH is not compatable with ethayerâs Lock Manager, or an any version of SHM Delay before v2.2.9. Either move on to use the SHM Delay or reinstall Mitch Pondâs DTH.
Hi ,
Iâm facing same issue. The keypad just doesnt respond to codes. I reinstalled Mitch Pondâs DTH, but still nothing. Nothing happens when you key in any code Any help ?
Best,
Fab
This issue was resolved a long time ago. The original mitch dth is no longer used by any apps and doesnât have the necessary patches to keep it up to date with the platform changes.
Make sure youâre using the latest version of the Enhanced Zigbee Keypad DTH or which ever app/DTH youâre using (if they have a specific DTH for that app).
What keypad are you using?
Iâm using Iris V2 keypad on US hub and smarthings classic. I was using Mitchâs DTH. I dont have a need for delayed locking. Any step by step on how to switch DTH ?
What are you trying to do? Whatâs your goal for the keypad?
Installing or updating the DTH is easy. Step by step instructions here which cannot be allied to any DTH. Generally itâs better to exclude and re pair the device after updating to a different DTH due to changes in ways DTH initialize devices.
Below is a link to a modified version, by @arnb, of the Mitch Pond DTH to work after the platform changes. It may or may not solve your issue but itâs worth a shot since you were using the original DTH. I hope it works for you!
Hi thx for yory reply. the link is not working . Any updated link ?
Hi , basically run hello home actions (eg goodbye to lock SHM and welcome back to unlock SHM) after successfully inputting the right code. the device is outside home, thus no need for the delayed actions
You have a couple of options, it looks like youâre using SHM Delay, try starting over from scratch and see if that helps.
If you donât need the entry delay features then you can use a simpler approach if you have access to RBoy Apps. Install the Enhanced ZigBee Keypad device handler and install LUM SmartApp to program codes on your keypad and create actions when the codes are used, for example run the hello home routines, change Classic SHM state. You can create specific actions for each action button on the keypad (on, partial, away, night etc) and create separate actions for each code or global actions for all codes. The enhanced zigbee DTH also works with SHM Delay so you can switch between Delay and LUM in future if you choose.
Itâs best practice to keep only one device handler, so whatever approach you choose delete any used DTHâs to avoid problems later on due to a stale DTH issue on the platform.
Give me a bit. Arn has been updating things to work with the new app so some fits may be offline. Iâll look in the repo and see if I canât find another link for you.
I would hold off starting over, if using SHM Delay, until trying the new DTH.
Complete documentation for SHM Delay is at
[Release] SHM Delay Version 2.0
Thanks arnb !
I removed and added the device again, used the original Mitch Pond DTH. To a certain extent it worked (it now executes routines correctly. updates temprature ,strange thing is that motion sensor in the app is always on, even if no motion but not a big deal)
I tried the new DTH with your updates and functionality but unfortunately it didnât work. I think because Iâm using the original SHM smartapp , right? Iâm not in real need for the delay functionality.
The current DTH must be used with the current SHM Delay. ST changed silently changed data format requirements a while back. Please update to the current levels and you may have a happy holiday.
Thanks arnb ! I updated both the DTH and the SHM Delay smartapp using yours and they now work perfectly!! Amazing work! Happy Holidays !!!
