215 posts were split to a new topic: [OBSOLETE] Rboy enhanced zigbee keypad DTH
On popular request:
Enhanced ZigBee Keypad Lock - Version 01.01.00
- Added support for UEI and Xfinity XHK1-UE keypads
- Updated DTH to support latest ST ZigBee framework
This is a low cost keypad and can be purchased on eBay for about $10 to $20. See first post for pairing instructions.
Did you try this and look at your IDE logs?
The V3 device behaves differently from the V2 devices. From the release post above:
Does anyone know if this is compatible with the Zipato mini keypad?
Zipato mini a Z-Wave keypad, this DTH will only work for ZigBee keypads and has been certified/tested with the keypads listed in the first post.
For those looking for weatherproof plastic mounting boxes to work with the UEI/Xfinity XHK1, I settled on the Arlington DBK88W and DBK88C. I really wanted to use the 5" square version but the XHK1 measures an 1/8" too big.
I wish there was a weatherproof version that could be used for garage doors and arming/disarming before you enter the home.
EDIT: Side by side detailed comparison of the keypads in the first post
Nothing like looking at the real stuff and/or some data points. A few comparisons of the some of the keypad models. The Centralite retail model is used here for comparison (dimension wise it’s similar to the Xfinity Centralite, features are slightly different)
The IRIS v3 is big (but it also has a LOUD siren), the Centralite is the thickest and the XHK is the thinnest (personal favorite and IMHO the sleekest/lowest profile). Feel free to share your thoughts.
I’ve been looking for a second keypad, but now I haven’t been able to find anything. When is the new centralite keypad coming out, and how much are they selling it for?
Wow! Thanks for the side by side comparison. I was mistaken. So you’d recommend the XHK keypad? Gotcha. I’ll forward to my friend and when I’m ready I’ll get it myself.
One of the most common questions we receive from users is around mounting the keypad in an outdoor enclosure in extreme weather to keep it safe from the elements.
Each keypad behaves differently in the enclosure. We do NOT recommend using the IRIS v3 (IL021) with an enclosure since it seems to constantly trigger the motion sensor. However in out tests the other keypads (IRIS v2, Xfinity XHK1, Xfinity Centratlite and Centralite Retail) do reasonable well with outdoor coverings. Do keep in mind that when using a covering it may interfere with the motion sensor and accuracy of the temperature sensor.
Here is an examples of a simple gang box covering with a clear lid that can be used as a keypad covering for outside for about $8
Thanks for the post!
Do you know any keypads that have the CE mark so it may be shipped to Europe?
Zigbee is international so it’s a bit odd none of these devices are available with a CE mark.
Just got my xhk1-ue (thanks for the link) and my subscription to http://rboyapps.com/ and everything is working GREAT within 10 mins!! Now I just have to find a weatherproof housing that fits (It a little to big for the one posted…) any ideas??
I feel it’s worth mentioning since it doesn’t seem to be said at all here and you won’t find out until you try to install this device handler - this DH is not free.
Currently it’s $40 USD for lifetime access (to all of their other apps as well including those mentioned here). Just something to be aware of before you go out and start buying keypads
You pretty much have to get them from eBay. None of these keypads are produced anymore. I can’t recall the last time anyone mentioned they got a bad keypad from eBay. Mine was a UEI for $20. It looked new and works great. I’ve had it for about a year now.
Enhanced ZigBee Keypad Lock - Version 01.10.00
- Added support for the Scout keypad
- A small touch screen keypad (see first post for comparative details).
- Uses 2 x CR123A batteries
- Has two arming modes, Lock (away) and Sleep (Stay).
- Does not have a panic button or a built in alarm or chime
- Does have a tamper notification and proximity (motion) sensor
- Has very interesting feature where you can set it to lock/arm without a user pin (i.e. one touch direct arming) or with a user pin. This setting can be changed from the device settings page
@Madpup the Scout keypad can be bought from Scout or from Amazon for about $50
That looks pretty sweet, although I do wish it had an alarm. I assume it is restricted to 4 digits like the others, right?
Care to comment on the overall usability compared to the others?
You can see the comparative feature tables and picture comparing it to other keypads at the bottom of the first post.
Two striking things about the keypad, it’s has a very sensitive touch panel which makes it super sleek and it much smaller compared to the other keypads. It’s as thick as the IRIS v3 but half the height/width - comparative picture in the first post.
The really nice feature we liked about this keypad was the option to enable/disable the user pin for locking the keypad (Arming). This opens up options for how you want to use it, place it somewhere for a quick arm or place it outside and enable the 4 digit user pin.
Thank you for adding the support for the Scout keypad. I did not end up buying one because it did not have the ability to beep.
I found a web site that sells new Centralite key pads here (https://www.gokeyless.com/product/centralite-3400-g/). The big reason I want a keypad is for the beeping when a door is opened and the alarm is still armed. I can’t tell you how many times the alarm has been set off because someone forgets to disarm it. I tried using the detailed notifications setting with echo devices but that was too much (the 60 second exit delay would cause all the echo’s in the house and barn to go crazy with the countdown).
GoKeyless was really good. I placed an order for two Centralite keypads and they both arrived 2 days later. Now I just have to set them up and hopefully will have beeping if someone opens a door and the alarm is armed.
