I’ve got some z-wave lights as well as a ZigBee Dimmer Switch (45857GE). The Z-Wave switches have a setting to change the LED indicator; however, the ZigBee Switch does not. I’ve search for some custom device handler code, but cannot find a solution to add the LED indicator to the ZigBee switch. Is that setting not available thru the API at the moment or does someone have some code they can share to allow this customization?
Thanks in advance.
