JDogg016
(Justin)
May 30, 2017, 1:15pm
1
I just installed and setup the GE Zigbee dimmer switch. The device type in the IDE reads Zigbee Dimmer and everything works well
BUT
Ther is no ability to turn off the little blue LED on the switch. Is there an alternative device type I can use for this?
Can try this one. I’m not a coder so I can’t tell from the GitHub code if it’ll do what you want. But give it a shot.
* Copyright 2015 SmartThings
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
* GE/Jasco ZigBee Dimmer
* Author: SmartThings
* Date: 2015-07-01
metadata {
definition (name: "GE ZigBee Dimmer", namespace: "smartthings", author: "SmartThings") {
This file has been truncated. show original
As I understand, the ZigBee spec does not have a specification for notification LEDs on/off, just blink. However there is a manual key press combination to disable the LED.
Hello,
I have a combination of Zwave and ZigBeeGE power switches, I can disable the blue LED on the Zwave ones. However, my question; is it possible to control it on the ZigBee switch?
