Zemismart curtain?
Hi, I wanted to know if this tent works with the SmartThings hub and if anyone has used it as it is
I haven’t tried it , but others is reporting that this should work with zemismart tuya curtain.
https://bestow-regional.api.smartthings.com/invite/qWjB0pNyY62y
Links that start with “Callaway“ are the ones you use after you have already subscribed to a channel. If you give that link to someone else, they will get a “ 403 forbidden“ error message.
Instead, you should share the invitation link that is used to subscribe to the channel for the first time. That typically has either “bespoke” in the URL or “invitation“.
My bad… It’s fixed now
