They don’t have anything to do with the z-wave repair. Live logging is showing a lot more activity than just z-wave, and SONOS is one that logs status events regularly. See my post above about how to open a hub event log window.
Does the Z-Wave Repair info not show up in the hub event log any more? I’ve ran it a couple times and when I click it in the IDE, I just get this JSON response
{"message":"Z-Wave network repair initiated - Click to view progress"}
I watch the hub log and nothing appears
Run live logging… you should see it there… If you have Hue connect/bridge, Sonos connect… you will see under those too… Go figure whythe last two options…
I’m not seeing anything there either. I remember previously seeing events in the hub log, but nothing now in either the live log or the hubs event log.
- Go to IDE via any browser on your computer/laptop.
- Go to My Hub Utilities…Don’t click on repair as of now.
- Open Live Logging in another tab or window…
- Now run zwave repair… This page will blank out and say "“Z-Wave network repair initiated - Click to view progress” - This is a new behavior that I am seeing.
- Go to the Live Logging tab. It should be there,
For some reason, I had to do a disconnect hub, then reboot hub. Now I’m seeing the repair in the log. My messed up devices seem to be working again. Thanks for the help
Once you get a UART error you can’t add a device nor repair until you reboot your hub. The hub will automatically reboot if you get this error during a repair but not otherwise.
I reported this to support a while ago but they didn’t seem concerned since there is a workaround.
Hi JD – I am having this exact issue at 5 minutes and 5 seconds. Did you ever figure out the root cause?
Kristopher
