Prime Day comes early.
Starting today, you can get up to 25% off a select range of Aeotec devices on Amazon.com.
Newsletter exclusives.
25% off 2 x Range Extender 6 . But be quick, this offer is limited to the first 50 buyers only.
Use the promotion code RANGTENDER6 at checkout.
15% off Multisensor 6 with Battery using the promotion code MULTISENSOR6 at checkout.
15% off Z-Stick Gen5 , the best tool to build your our smart home gateway with, using the promotion code ZSTICKGEN5 at checkout.
Also available this Prime Day.
NanoMote Quad , our 4-button remote control, $9 off. Normally $44.99
WallMote Quad , our 4 button wireless wall switch, $10 off. Normally $59.99
Nano Dimmer , used to convert any dimmer to a Z-Wave dimmer, $10 off. Normally $59.99
Water Sensor 6 , Z-Wave’s most high-tech leak detector, $10 off. Normally $59.99
