Z-Wave Garage Door Opener Recommendations
It’s almost 2021 would love to know the following that works with smartthings 3rd gen Hub:
  1. What smart Z-wave garage door openers are people using?
  2. In place of a garage door opener, what controller is everyone using?
Thank you,
Santiago
This has been working great for me.
“Z-Wave Garage Door Opener Remote Controller Accessory - GD00Z-4” https://www.gocontrol.com/detail.php?productId=4
Am using the Aotec one https://aeotec.com/z-wave-garage-door-controller/
Works well with my existing setup.
@Jake_Mohl Did you have to do anything special to get it to show up right on your smartthings? Are you using 3rd gen hub for ST.
V2 hub.
Try factory resetting it.
Perform a device factory reset before pairing by pressing the include button on the GD00Z 5 times.
Then go through the pairing process. You then have to pair the sensor to the control unit.
In the link below is instructions how how to repair the sensor. You don’t have to manually flip it like how he says. I just pressed the garage door button to open the door and again to close it.
