Using Smart Lightning smart app in the SmartThings IOS app 1.5.39 and the Sunrise/Sunset triggers are not working. They are supposed to turn a plug on/off.
Have checked location and it is set correctly
It will also send me an alert at sunrise and sunset, if I create a custom routine so the time zone appears to be correct
Yes, you are missing the Hello Home section which could cause the issue you described earlier. You should contact ST support and request they reinstall that for you.
I’ll tag @Brad_ST but no telling when he might be able to restore it for you so go ahead and contact ST support
contact ST and report you are missing the Hello Home section and ask them to reinstall it in your Smartapps. They should understand and install it for you.
@Its2loud your image is showing you are in a different section. Follow the instructions I posted above. You are going to Smartapps from the menu. You need to go to Locations > SmartApps in the Home Location listing.
