Hello all. I want to automate my heating at home (hot water radiators) since it is not working very well when I am using it manually. Here’s the thing: I would like these TRV’s to get their set temperature through the ST-network, preferably from some Aeotec Multisensors I have around. So the flow would be like this:
The sensor senses that the temperature is too low/hot.
It sends this info the the hub.
The hub applies some smartapp magic and sends a command to the TRV’s to turn on/off.
Is this possible? And if so, which TRV’s can I use?
I use Honeywell TRVs from Amazon, around £25 each and use them exactly as you describe. I use the Normally Open version so the heating will still work if ST ever goes offline… I use the Virtual Thermostst app to turn them on and off. Works very well, except I have to remember to use negative logic, as they switch on when up to temperature, so I treat them as coolers…
Oh, that sounds nice. But for $25? And these work over UK/EU z-wave? Since the price is listed in dollars I wanted to make sure. And do you have a link if so?
Oh, sorry. I blame myself for being absurdly tired today. Thank you so much! Will check them out.
Question: Does these require a permanent connection to power? It seems they do, and if so I cannot use them
Z-wave and battery powered with (apparently!) the ability to change the set temp through the TRV by twisting it like a normal old non-smart TRV makes them quite tempting imho, though also very expensive to kit out the entire house…
Not only battery-powered, but rechargeable? Oh, heaven. I want those now. I have been looking at Popp and Eurotronic’s TRVs, but when I asked the respective companies both of them said that they couldn’t be used the way I wanted.
They run on 240 volts, so I run the cable to a ST compatible outlet and control them that way - they are not directly controllable by ST as they are essentially just a dumb mains operated valve. To fit them just unscrew your current TRV and install. Mine came with a conversion ring to fit several types of radiator, but I do have one radiator with a very odd valve which I will have to replace at some point…
