Welcome code
in the ST app, tap on Menu and select Contact us. You will need to send a image of the bottom of the hub that clearly shows the serial number.
or SmartThings support and scroll to the bottom of the screen
Yes. I have the ticket number and i’ve already sent the email but they response is really slow…
I have the same problem just inboxed you to see if you can help? Thanks
@SamsungZell is no longer active on the forum.
You will need to contact ST support directly if you need to get a Welcome code. You should include a photo of the bottom of your hub that clearly shows the serial number on your hub.
Following email addresses support@smartthings.com, support@smartthings.co.uk don’t work anymore.
For me what worked to get the Welcome code for Smartthings hub v2 was this page
https://samsunguk.my.site.com/SmartThings/s/
I reset my hub and it is asking for a welcome code. Please help!
Hi @Rhonda_Beyer
I sent you the welcome code through a DM
open the case up. It might be written inside.
