After you have signed into your dashboard, using the menu button select settings, then you should see a tab for integrations. The instructions for IFTTT integration is there.
You will not actually see your IFTTT applets using WebCoRE. Not being snarky, but did you read the entire page concerning integrations? There is more info below the Lifx integration that should explain what you need to do.
The folks over at the WebCoRE community forum are always willing to help. I suspect you’ll get a quick response if you post there (if you haven’t already).
Not much help under integrations (I’m using Webcore on a computer) and I’ve already looked through the Wiki. Couldn’t find much there either. I’ll try on the Webcore forum.
You need to go to IFTTT and enable the Maker WebHooks applet. That will provide you with a key that you need to copy and paste into webCoRE’s Settings > Integrations > IFTTT. Once that is done and tested, in the piston, use a task Make IFTTT Maker request (name may vary). That would be all, pretty much.
I’ve got the connection made to IFTTT but don’t have a clue as to what to do after that. I did add a task and chose "send an IFTTT maker event. Now what? Event? Value? What?
Go back to IFTTT and create an applet. Use the WebHooks Maker channel as input (the if) - it will then all make sense. You create an “event” or a keyword the WebHooks channel should respond to. That same word is used in the Make IFTTT request task in webCoRE - it’s what glues them together. You can call various “events” in IFTTT so pick an event name that is representative of what you want it to do. Then on the then side of the IFTTT applet, add whatever you want it to do.
Maybe I’m doing it backward, but what I’m trying to do in Webcore is “if this condition is true” then run this IFTTT applet. Is that what you’re describing above or is your example passing data FROM IFTTT to Webcore?
webCoRE gets IFTTT to execute an applet. Use the task (part of an action) to do this, the reverse is achieved with an IF using the virtual device IFTTT. You want the IFTTT task, create an applet and define the event name - they may call it a trigger? Don’t remember exactly
