I added the Garage Door Monitor smartapp, but it doesn’t recognize my garage door controller I guess (GoControl). When I try to set it up, it says no devices found.
Next I was going to try the Smart Home Monitor in the Classic app, but SHM is not anywhere to be found. Most instructions say it’s on the dashboard, but there’s nothing on the dashboard other than Favorites, and I don’t see any way to create it.
Am I doing something wrong? I’m in the USA, so I assume the SHM would be available to me?
Welcome! If you are a new user, you should really consider using the new SmartThings app and using smartthings home monitor (STHM) in it. They are in the process of phasing out the Classic app and for new users they have removed SHM and routines. Plus GoControl is available through the new app by clicking on add device > by brand > GoControl.
I did add my GoControl garage door opener just fine, it’s the Garage Monitor smartapp that doesn’t recognize it. That’s where it says “no devices found” if that makes sense.
I would use STHM but I can’t see anything where I can do what I want in there. I just want to re-lock my door of its been unlocked for 20 minutes, or monitor my garage. STHM seems to be specifically for monitoring your house when you’re not there - or is that not right?
