Hi Brian,
Back with you after much futzing with it… I believe part of my issue was signal to/from the HEM… I’ve made some installation changes that are resulting in a lot more telemetry… here’s a snippet of log data now.
0410f66d-81dd-4b27-b534-d66a2c500287 9:52:14 AM: debug Parse returned Aeon HEM v2 amps one is 13.70 A A
0410f66d-81dd-4b27-b534-d66a2c500287 9:52:14 AM: debug Parse returned Aeon HEM v2 amps two is 9.62 A A
0410f66d-81dd-4b27-b534-d66a2c500287 9:52:14 AM: debug Parse returned Aeon HEM v2 amps is 23.32 A
0410f66d-81dd-4b27-b534-d66a2c500287 9:52:14 AM: debug Parse returned Aeon HEM v2 energy is 0.44 kWh
0410f66d-81dd-4b27-b534-d66a2c500287 9:52:14 AM: debug Energy Since Last Reset: 155.73
0410f66d-81dd-4b27-b534-d66a2c500287 9:52:14 AM: debug Parse returned Aeon HEM v2 volts is 122.86 V
0410f66d-81dd-4b27-b534-d66a2c500287 9:52:02 AM: debug Parse returned Aeon HEM v2 power is 2783 W
0410f66d-81dd-4b27-b534-d66a2c500287 9:52:02 AM: debug Parse returned Aeon HEM v2 power one is 1662 W W
0410f66d-81dd-4b27-b534-d66a2c500287 9:51:44 AM: debug Parse returned Aeon HEM v2 amps two is 9.55 A A
0410f66d-81dd-4b27-b534-d66a2c500287 9:51:44 AM: debug Parse returned Aeon HEM v2 amps is 22.7 A
0410f66d-81dd-4b27-b534-d66a2c500287 9:51:44 AM: debug Parse returned Aeon HEM v2 amps one is 13.16 A A
0410f66d-81dd-4b27-b534-d66a2c500287 9:51:38 AM: debug Parse returned Aeon HEM v2 power is 2706 W
0410f66d-81dd-4b27-b534-d66a2c500287 9:51:14 AM: debug Parse returned Aeon HEM v2 amps one is 12.97 A A
0410f66d-81dd-4b27-b534-d66a2c500287 9:51:14 AM: debug Parse returned Aeon HEM v2 energy is 0.40 kWh
0410f66d-81dd-4b27-b534-d66a2c500287 9:51:14 AM: debug Energy Since Last Reset: 155.73
0410f66d-81dd-4b27-b534-d66a2c500287 9:51:14 AM: debug Parse returned Aeon HEM v2 power is 2678 W
0410f66d-81dd-4b27-b534-d66a2c500287 9:51:14 AM: debug Parse returned Aeon HEM v2 volts is 122.76 V
0410f66d-81dd-4b27-b534-d66a2c500287 9:50:44 AM: debug Parse returned Aeon HEM v2 amps two is 9.39 A A
0410f66d-81dd-4b27-b534-d66a2c500287 9:50:44 AM: debug Parse returned Aeon HEM v2 amps one is 12.90 A A
0410f66d-81dd-4b27-b534-d66a2c500287 9:50:44 AM: debug Parse returned Aeon HEM v2 amps is 22.28 A
0410f66d-81dd-4b27-b534-d66a2c500287 9:50:38 AM: debug Parse returned Aeon HEM v2 power is 2657 W
0410f66d-81dd-4b27-b534-d66a2c500287 9:50:38 AM: debug Parse returned Aeon HEM v2 power one is 1563 W W
0410f66d-81dd-4b27-b534-d66a2c500287 9:50:32 AM: debug Parse returned Aeon HEM v2 power one is 746 W W
0410f66d-81dd-4b27-b534-d66a2c500287 9:50:32 AM: debug Parse returned Aeon HEM v2 power is 1841 W
0410f66d-81dd-4b27-b534-d66a2c500287 9:50:26 AM: debug Parse returned Aeon HEM v2 power one is 634 W W
0410f66d-81dd-4b27-b534-d66a2c500287 9:50:26 AM: debug Parse returned Aeon HEM v2 power is 1614 W
0410f66d-81dd-4b27-b534-d66a2c500287 9:50:20 AM: debug Parse returned Aeon HEM v2 power one is 746 W W
0410f66d-81dd-4b27-b534-d66a2c500287 9:50:14 AM: debug Parse returned Aeon HEM v2 amps two is 9.32 A A
0410f66d-81dd-4b27-b534-d66a2c500287 9:50:14 AM: debug Parse returned Aeon HEM v2 amps one is 6.42 A A
0410f66d-81dd-4b27-b534-d66a2c500287 9:50:14 AM: debug Parse returned Aeon HEM v2 energy is 0.36 kWh
0410f66d-81dd-4b27-b534-d66a2c500287 9:50:14 AM: debug Energy Since Last Reset: 155.73
0410f66d-81dd-4b27-b534-d66a2c500287 9:50:14 AM: debug Parse returned Aeon HEM v2 amps is 15.74 A
0410f66d-81dd-4b27-b534-d66a2c500287 9:50:14 AM: debug Parse returned Aeon HEM v2 volts is 122.8 V
0410f66d-81dd-4b27-b534-d66a2c500287 9:50:08 AM: debug Parse returned Aeon HEM v2 power is 1823 W
Prior to pulling those logs, I did some measurements in my panel with my handheld current clamp ammeter in concurrence with the UI snapshots shown below.
First with power going out to the grid (generation greater than consumption)
Solar gen measured at insertion pt: Leg 1=14.5 amps Leg 2=14.5 amps Total = 29 amps
Current Measured next to clamps: Leg 1=3.4 amps Leg 2=9 amps Total = 12.4 amps (going to utility)
Second with power coming in from the grid (consumption greater than generation, I turned on the dryer)
Solar gen measured at insertion pt: Leg 1=15.4 amps Leg 2=15.4 amps Total = 30.8 amps
Current Measured next to clamps: Leg 1=21.2 amps Leg 2=12.6 amps Total = 33.8 amps (coming from utility)
Note solar production was slightly higher as it was a few minutes later and the sun is still rising toward apogee.
Note also the negative display in Watts yet positive display in Amps… is that the intention of how it should show opposite current flow?
Then I tried hitting your “Toggle” and this is what I get:
Which totally confuses me…
when I toggle again it goes back to the prior display content.
