This weekend I installed four DZS15-1BZ switches with four VP0SR-1LZ remotes and in each case the VP0SR-1LZ can turn the lights off, but it can’t turn them on.
If I turn the lights off with the VP0SR-1LZ when I use the DZS15-1BZ the lights flash on and immediately off the first two times I push the switch, the third time they stay on.
The LED for the VP0SR-1LZ never seems to turn on. The LED for the DZS15-1BZ works as I expect (on when the lights are off and off when the lights are on).
What did I do wrong in wiring each of the VP0SR-1LZs? (At least I was consistent)
What I tried to do is connect the common wire and the wire that went to the red screw on the DZS15-1BZ to the BK screw on the the VP0SR-1LZ, the wire that went to the YEL/RD screw on the DZS15-1BZ to the YEL/RD screw of the the VP0SR-1LZ and added a pigtail to the neutral bundle in the box and connected it the WH screw on the VP0SR-1LZ.
