My Leviton master switch DW15S-1BZ works perfectly. However the remote switch DD0SR-DLZ will turn the light off one time, will never turn the light off again, and never turns the light on.
ls there something I’m missing or should be on the lookout for? My attempt at a drawing is below.
Looks like you wired it with the switch and remote in the wrong boxes (which is forgivable, since Leviton doesn’t label the line and load wires) and then, with that not working at all, changed things around until, at least, the master worked.
If your line and load are coming into the same box (and your remote box only has the one set of wires going out to it), it’s pretty obvious that the master goes into the box with the main wiring. However, when your line-power and load are connected to separate boxes, then it’s not very clear which goes where… but the remote needs to go in the box with line-power and master goes in the box to the load.
Here’s why/how: The remote needs: 1) line-power, 2) neutral, 3) a way to send it’s signals to the master. The master needs: 4) line-power, 5) neutral, 6) signal from the remote, and 7) to send its switched power to the load. To do this: you need to:
Put the remote in the box with the line power and hook the line power to remote’s BK (so #1 is done) and also hook the red wire to the other box to BK so that line-power arrives to the master. Connect that red wire to master’s BK (so #4 is done)
Wire the neutral from the line power bundle to remote’s WH (so #2 is done) and also wire the white wire to the other box to this so that neutral arrives to the master, and wire that white to master’s WH (so #5 is done) and also connect load’s white to this.
Wire the black wire to the other box to remote’s YL/RD (so #3 is done) and wire the other end of it to master’s YL/RD (so #6 is done).
Finally, wire master’s switched output RD to load’s black wire (so #7 is done).
So, from your diagram, the tying of black to red on remote’s BK terminal is appropriate… you’re just doing it at the wrong box. You need to do that at the box with the line-power. Then, at the other end, you need to deviate from your diagram in that red wire goes to BK and load’s black goes to master’s RD.
