I’m using the above door/window sensors with the native ST DH which reports both contact sensor and temperature. I have no need for the temperature readings on any of my 26 sensors.
Is there a different DH I can use to bypass the temp updates and save some battery life ?
I had 1 of 12 that ate batteries…The others last quite a while before needing battery replacement. Unless you just don’t like seeing extra info, you might consider leaving well enough alone.
