Visonic MCT-340 E
I’m brand new to the board and SmartThings so I apologize ahead of time if this is answered. I’m not a developer or have a background in this type of thing.
I purchased a few of the Visonic MCT-340 E door/window sensors. When I try to add a device, nothing is showing up. All I have to do is select add a device, correct? It looks like maybe in the past I needed to be a developer or have some back end knowledge to add these but I see it says they should be native to the app now.
Are there easy step by step instructions to set these up? I appreciate the help!
They are natively supported and use the SmartSence Open/Closed Sensor.
https://www.mydigitaldiscount.com/connecting-your-visonic-mct-340-e-window-door-sensor-to-smartthings.html
when you start the pairing process in ST by choosing Add a Device…
  1. Remove the battery cover.
  2. Press and release the tamper switch for 1 to 2 seconds.
  3. Close the battery cover.
Mine go offline quite a bit. Have to do what jkp said to get them back online.
Hi all! Sorry to bring up and old thread but I’ve got these same door/window sensors and I cannot get them to connect to my ST hub. I’m a brand new ST user (formerly with Iris and then with Wink). Any help would be appreciated. I have like 30 sensors I bought and am
trying to connect.
Try resetting them, then try to pair to ST
Hi!
I have a bunch of them (Visonic Window/Door Sensor for Samsung SmartThings - MCT-340 E) which I bought back in 2017. They were all working fine with the old app.
I migrated to the new app a few days ago. After a few initial issues with the new app, I did end up deleting and re-pairing them in the new app.
Many things now work OK:
  • The sensors do show up in the list of devices in the new app
  • They work OK in the SmartApps (mostly Smart Lighting) that were migrated over to the new app
  • The SmartThings Home Monitor in the new app does alert correctly when my doors are opened
But there are a couple of things that do not seem to work correctly:
  • In the device list of the new app, the sensor status (open/close) is not shown. In addition, when I tap on those sensors, the new app shows an error: “Can’t connect to the device. Check it and try again.”
  • When I try to create a new Automation in the new app I can’t see any of them listed (Menu > Automations > Plus > If > Plus > Device status)
What experiences have others observed with those sensors after migrating to the new app?
Login to IDE at https://account.SmartThings.com go to the My Devices section, open each visonic sensor and make sure the device type is set to smartsense open/closed sensor. If they were set to a custom device handler, you may want to remove it from the Device Handler section so it does not cause issues in the future.
I have some visonic sensors and they work fine - they display open/closed and work in automations. :slight_smile:
Note: when building automations, sometimes you need to go into tHe device status section twice in order for all device to load. The first time, not all devices may load, go back, load it again and you will likely get all the devices to load.
What jkp said worked. Would like to know why automations only let me specify temperatures up to 104 degrees. Maybe that’s not for this discussion, but I am trying to use the temp sensor in my visonic sensor for an automation that turns my network controller fans on. Might have to use IFTTT for this with this sensor. :face_with_raised_eyebrow:
Don’t have an answer. Automations do have a few areas that are limiting for reasons no one seems to know. For example, a limit of 60 minutes before/after sunset or sunrise where the Classic app did not have such a limit in routines.
Another option you can look into is webcore.
Sorry to revive a very old thread. I had purchased these device 2 year back but finally getting to pair it with Smarthings but it is not connecting. I know it says it is natively supported but I cannot find the manufacturer name in th elist. I tried to use scan nearby but it still did not find. I even removed the battery and held the tamper resistant switch for few seconds but nothing. The sensor has red led flashing but I don’t see the device in Smartthing. Anyone knows how to pair it?
I am in the same situation, except I totally reset my hub and it deleted them all, now I can’t seem to figure out how to add them back using the new app.
Thank you.
@gsgentry I am also in the same situation. Have you add any luck since your post 12 days ago?
My sensors are working OK once I changed device type to smartsense device type. Looks like you can also change to Tyco Door/Window Sensor. See below link.
One thing I’d like to be able to get from these sensors is the tamper output to alarm if someon opens battery door. Is that possible with any currently operational jdevice handlers?
I can’t even get these sensors to recognize in the new ST app. I currently have no sensors showing and when I add, nothing.
Surely some of these guys around here can figure this out and help troubleshoot it.
To put the sensor pairing mode, you have to take
battery out , hold reset button for 2 sec, and let go of button after putting the battery in , then red light will blink. Should be able to detect sensor after the red light is blinking :slight_smile:
This is wrong , I am not sure why this instruction was giving . To put it in pairing , the battery needs to be removed , hold down rest button and put battery back. The red light will blinks on/ off, that’s when we know it’s in pairing mode.
Hi, I had problems to add this sensor, but I had a custom DH to manage this device, I needed to change the current installed sensors to another DH and then Remove the custom DH , after that , The sensor was recognized.
