Is there any process file bug reports on existing vid? I am trying to use generic-button and notice it does not support all possible button values. From what I can tell it only works with pressed and held. I ended up using generic-button-4 which has the states I need but it would be nice if it was consistent.
In the same light, whats the process to create a new vid or enhance an existing?
Is there any documentation for writing a vid? I notice the developer portal has a location to upload a template but am not sure what the official structure is. Would it be visible to my device handler if I create a device profile in the portal?
Odd. All the values seem to show up when you read the presentation resource associated with it. However I’ve only got a few handlers that use the Button capability and they all work fine without a vid: anyway. Are you setting the supportedButtonValues attribute? I can’t remember if that removes the settings you don’t need or adds the one you do.
The 2 mentioned show up to assign actions while others are not visible. Either way what I really want is a generic-dimmer + Button for up/down. For now I implemented as a child component, but it’s not clean as I would like. My use case is to support the Jasco z wave dimmer double click. I can share my github if anyone is interested.
I ran into the issue again where I need to create a vid that does not exist. My current approach is to create child devices, but that has the problem of increased clutter. Any pointers would be appreciated.
