Fubie
September 19, 2015, 3:45am
1
I just got my v2 hub today and setup my Harmony, sonos, hue, and amazon echo.
But it will not find both the Fibaro Motion Sensor or ST Open/Close sensor.
I pulled the tabs on the sensors and went to the marketplace, and connect new device. after 10min it detected nothing.
Then I tried adding them individually by going to Safety & Security, Motion Sensors, Fibaro, Fibaro Motion Sensor, connect now.
or
Safety & Security, Open/Closed sensors, samsung smartthings, and I tried both selections.
Am I doing this the wrong way?
twack
(Todd Wackford)
September 19, 2015, 4:17am
2
You need to put the devices in pairing mode while the search is active. For the fibaro, press the b button 3 times.
I’m having the same problems. Seem a lot of people are having problems with v2 hub. The green light doesnt even flash on the hub when i try to pair.
Fubie
September 19, 2015, 1:49pm
4
Luckily I do not have a defective hub as I was able to pair most everything else.
Also when my hub is in pairing mode the green light does blink.
schettj
(John S)
September 19, 2015, 1:57pm
5
Try doing a general exclusion first for any device that won’t pair (if it’s zwave) or if it’s zigbee see if there is a way to reset the device physically.
Fubie
September 19, 2015, 2:07pm
6
That worked! They are both working now! Thanks for your help guys!
