Using HUE Motion Sensor in HUE hub and see temperature and brightness in ST hub
I use the Hue motion sensor connected to the Hue hub, for activation with brightness and use scenes.
Is there a way to see the temperature and brightness of the sensor on the ST without connecting it directly to the ST hub?
thanks
The hue beta driver:
will allow you to do this:
with the following able to be interrogated from a routine:
and set by a routine:
