Ive brought 2 hue multi sensors under the inpreshion that thay connect to the smartthings hub directly. Ive managed to get them connected to the hub but coming up as unknown. Is there anyway for this to work or am i doing something wrong or do i need the hue hub?
I personally don’t have these, but from what I understand they do connect directly to the ST hub without the hue hub - BUT - you need a device handler for these to be identified and to work properly. SmartThings has many device handlers, but with literally hundreds of devices out there, and new ones showing up all the time, either the device’s manufacturer has to create the handler, or as in most cases, the ST Community puts one together:
Thanks John worked a treat.
