Using Camera's to trigger security event
I found the basic commands for your camera, the following devicetype should work for at least your motion on/off. Not sure if the PIR sensor will work or not.
Also, after looking into this camera it IS possible to hardwire an output that you could tie into an open/close sensor with input terminals so that the D-Link camera could trigger an event. I haven’t heard of anyone trying it but it is at least possible.
