Problems with my Advanced D-Link IP Camera Device Type using hubAction
Hi, I’m very new to the whole world of SmartThings but have been trying to integrate my existing cameras into the platform. Using @pstuart 's Generic Camera Device as a starting point I’ve been trying to modify the code in order to add the ability to turn on and off the motion sensing. My intention is to allow myself to turn on the motion sensing when everyone is away so that it will automatically email me snapshots of any detected motion.
I think I already know what URL based commands I need to pass to the camera in order for it to do what I want:
DCS-942L:
ON: http://username:password@IP:Port/config/motion.cgi?enable=1&pir=1
OFF: http://username:password@IP:Port/config/motion.cgi?enable=0&pir=0
DCS-5020L:
ON: http://username:password@IP:Port/setSystemMotion?ReplySuccessPage=motion.htm&ReplyErrorPage=motion.htm&MotionDetectionEnable=1&MotionDetectionSensitivity=85&ConfigSystemMotion=Save
OFF: http://username:password@IP:Port/setSystemMotion?ReplySuccessPage=motion.htm&ReplyErrorPage=motion.htm&MotionDetectionEnable=0&MotionDetectionSensitivity=85&ConfigSystemMotion=Save
I’ve started with the DCS-942L because it is the simplest of the two and believe that I have it pretty close. Below is a copy of the hacked together devicetype, It’s basically just a bastardized version of @pstuart 's code with a little bit from @ethomasii 's DCS-930 code but it’s a start.
 *  Generic Camera Device v1.0.07102014
 *	Modified for the D-Link DCS-942L
 *  Copyright 2014 patrick@patrickstuart.com
 *  Modified 2015 blebson
 *  Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
 *  in compliance with the License. You may obtain a copy of the License at:
 *      http://www.apache.org/licenses/LICENSE-2.0
 *  Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
 *  on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
 *  for the specific language governing permissions and limitations under the License.
metadata {
	definition (name: "DCS-942L", author: "patrick@patrickstuart.com") {
		capability "Image Capture"
		capability "Sensor"
		capability "Switch"
		attribute "hubactionMode", "string"
    preferences {
    input("CameraIP", "string", title:"Camera IP Address", description: "Please enter your camera's IP Address", required: true, displayDuringSetup: true)
    input("CameraPort", "string", title:"Camera Port", description: "Please enter your camera's Port", defaultValue: 80 , required: true, displayDuringSetup: true)
    input("CameraPath", "string", title:"Camera Path to Image", description: "Please enter the path to the image", defaultValue: "/SnapshotJPEG?Resolution=640x480&Quality=Clarity", required: true, displayDuringSetup: true)
    input("CameraAuth", "bool", title:"Does Camera require User Auth?", description: "Please choose if the camera requires authentication (only basic is supported)", defaultValue: true, displayDuringSetup: true)
    input("CameraPostGet", "string", title:"Does Camera use a Post or Get, normally Get?", description: "Please choose if the camera uses a POST or a GET command to retreive the image", defaultValue: "GET", displayDuringSetup: true)
    input("CameraUser", "string", title:"Camera User", description: "Please enter your camera's username", required: false, displayDuringSetup: true)
    input("CameraPassword", "string", title:"Camera Password", description: "Please enter your camera's password", required: false, displayDuringSetup: true)
	simulator {
	tiles {
		standardTile("camera", "device.image", width: 1, height: 1, canChangeIcon: false, inactiveLabel: true, canChangeBackground: true) {
			state "default", label: "", action: "", icon: "st.camera.dropcam-centered", backgroundColor: "#FFFFFF"
		carouselTile("cameraDetails", "device.image", width: 3, height: 2) { }
		standardTile("take", "device.image", width: 1, height: 1, canChangeIcon: false, inactiveLabel: true, canChangeBackground: false) {
			state "take", label: "Take", action: "Image Capture.take", icon: "st.camera.camera", backgroundColor: "#FFFFFF", nextState:"taking"
			state "taking", label:'Taking', action: "", icon: "st.camera.take-photo", backgroundColor: "#53a7c0"
			//state "image", label: "Take", action: "Image Capture.take", icon: "st.camera.camera", backgroundColor: "#FFFFFF", nextState:"taking"
	standardTile("blank", "device.image", width: 1, height: 1, canChangeIcon: false, canChangeBackground: false, decoration: "flat") {
            state "blank", label: "", action: "", icon: "", backgroundColor: "#FFFFFF"
		main "camera"
		details(["cameraDetails", "blank", "take"])
    tiles {
        standardTile("refresh", "device.alarmStatus", inactiveLabel: false, decoration: "flat") {
            state "refresh", action:"polling.poll", icon:"st.secondary.refresh"
        standardTile("button", "device.switch", width: 1, height: 1, canChangeIcon: true) {
			state "off", label: 'Off', action: "switch.on", icon: "st.custom.buttons.rec", backgroundColor: "#ccffcc"
			state "on", label: 'On', action: "switch.off", icon: "st.custom.buttons.rec", backgroundColor: "#EE0000"
        main "button"
        details([ "take", "button", "refresh", "cameraDetails"])
    log.debug "Parsing '${description}'"
    def map = [:]
	def retResult = []
	def descMap = parseDescriptionAsMap(description)
	//Image
	if (descMap["bucket"] && descMap["key"]) {
		putImageInS3(descMap)
// handle commands
def take() {
	def userpassascii = "${CameraUser}:${CameraPassword}"
	def userpass = "Basic " + userpassascii.encodeAsBase64().toString()
    def host = CameraIP
    def hosthex = convertIPtoHex(host)
    def porthex = convertPortToHex(CameraPort)
    device.deviceNetworkId = "$hosthex:$porthex"
    log.debug "The device id configured is: $device.deviceNetworkId"
    def path = CameraPath
    log.debug "path is: $path"
    log.debug "Requires Auth: $CameraAuth"
    log.debug "Uses which method: $CameraPostGet"
    def headers = [:]
    headers.put("HOST", "$host:$CameraPort")
   	if (CameraAuth) {
        headers.put("Authorization", userpass)
    log.debug "The Header is $headers"
    def method = "GET"
    try {
    	if (CameraPostGet.toUpperCase() == "POST") {
        	method = "POST"
    catch (Exception e) { // HACK to get around default values not setting in devices
    	settings.CameraPostGet = "GET"
        log.debug e
        log.debug "You must not of set the perference for the CameraPOSTGET option"
    log.debug "The method is $method"
    try {
    def hubAction = new physicalgraph.device.HubAction(
    	method: method,
    	path: path,
    	headers: headers
    hubAction.options = [outputMsgToS3:true]
    log.debug hubAction
    hubAction
    	log.debug "Hit Exception $e on $hubAction"
def putImageInS3(map) {
	log.debug "firing s3"
    def s3ObjectContent
    try {
        def imageBytes = getS3Object(map.bucket, map.key + ".jpg")
        if(imageBytes)
            s3ObjectContent = imageBytes.getObjectContent()
            def bytes = new ByteArrayInputStream(s3ObjectContent.bytes)
            storeImage(getPictureName(), bytes)
    catch(Exception e) {
        log.error e
	finally {
    //Explicitly close the stream
		if (s3ObjectContent) { s3ObjectContent.close() }
def parseDescriptionAsMap(description) {
description.split(",").inject([:]) { map, param ->
def nameAndValue = param.split(":")
map += [(nameAndValue[0].trim()):nameAndValue[1].trim()]
private getPictureName() {
	def pictureUuid = java.util.UUID.randomUUID().toString().replaceAll('-', '')
    log.debug pictureUuid
    def picName = device.deviceNetworkId.replaceAll(':', '') + "_$pictureUuid" + ".jpg"
	return picName
private String convertIPtoHex(ipAddress) {
    String hex = ipAddress.tokenize( '.' ).collect {  String.format( '%02x', it.toInteger() ) }.join()
    log.debug "IP address entered is $ipAddress and the converted hex code is $hex"
    return hex
private String convertPortToHex(port) {
	String hexport = port.toString().format( '%04x', port.toInteger() )
    log.debug hexport
    return hexport
private Integer convertHexToInt(hex) {
	Integer.parseInt(hex,16)
private String convertHexToIP(hex) {
	log.debug("Convert hex to ip: $hex")
	[convertHexToInt(hex[0..1]),convertHexToInt(hex[2..3]),convertHexToInt(hex[4..5]),convertHexToInt(hex[6..7])].join(".")
private getHostAddress() {
	def parts = device.deviceNetworkId.split(":")
    log.debug device.deviceNetworkId
	def ip = convertHexToIP(parts[0])
	def port = convertHexToInt(parts[1])
	return ip + ":" + port
def motionCmd(int motion)
    def host = CameraIP
    def path = "/config/motion.cgi?enable=yes&pir=yes"
    def headers = [:]
   	if (CameraAuth) {
  sendEvent(name: 'motion', value: motion)
  if (motion == 1){
  try {
    	method: "POST",
    	path: "/config/motion.cgi?enable=yes&pir=yes",
    	headers: headers
    //hubAction.options = [outputMsgToS3:true]
    log.debug hubAction
    hubAction
  else
  path = "/config/motion.cgi?enable=no&pir=no"
  try {
    	method: "POST",
    	path: "/config/motion.cgi?enable=no&pir=no",
    	headers: headers
    log.debug hubAction
    hubAction
  return hubAction
def on() {
	log.debug "Executing motion detection"
    motionCmd(1)
    sendEvent(name: "switch", value: "on")
def off() {
	log.debug "Disabling motion detection"
    motionCmd(0)
    sendEvent(name: "switch", value: "off")
def setMotion(status) {
	log.debug "Status: $status"
    motionCmd(status) {
        sendEvent(name: 'motion', value: status)
When I press the ‘Record’ button it shows that it runs the hubAction command but then nothing happens;
5797fd8f-1745-4b7d-968c-d97bc91a73cc 10:04:36 PM: debug POST /config/motion.cgi?enable=yes&pir=yes HTTP/1.1
Accept: /
User-Agent: Linux UPnP/1.0 SmartThings
HOST: 192.168.1.65:80
Authorization: Basic XXXXXXXXXXXXXXXX
5797fd8f-1745-4b7d-968c-d97bc91a73cc 10:04:35 PM: debug The Header is [HOST:192.168.1.65:80, Authorization:Basic XXXXXXXXXXXXX]
5797fd8f-1745-4b7d-968c-d97bc91a73cc 10:04:35 PM: debug Uses which method: GET
5797fd8f-1745-4b7d-968c-d97bc91a73cc 10:04:35 PM: debug Requires Auth: true
5797fd8f-1745-4b7d-968c-d97bc91a73cc 10:04:35 PM: debug path is: /config/motion.cgi?enable=yes&pir=yes
5797fd8f-1745-4b7d-968c-d97bc91a73cc 10:04:35 PM: debug The device id configured is: c0a80141:0050
5797fd8f-1745-4b7d-968c-d97bc91a73cc 10:04:35 PM: debug 0050
5797fd8f-1745-4b7d-968c-d97bc91a73cc 10:04:35 PM: debug IP address entered is 192.168.1.65 and the converted hex code is c0a80141
5797fd8f-1745-4b7d-968c-d97bc91a73cc 10:04:35 PM: debug Executing motion detection
Any help getting this working would be greatly appreciated!
Not sure what the problem with the hubaction is but you might want edit out the Authorization Basic lines of your post and then change that password anywhere you use it. :wink:
It looks like it is doing a POST not a GET in the hubaction. Does the camera accept POST for that command?
Look at my devicetype to see how i have configured motion detection. It may help you with yours.
I’ve tried both POST and GET commands. The devicetypes i’ve seen that supposedly worked (though not for me) all used the httpPost command and an external IP/Port. I’m attempting to convert this to the local address.
I took a look at your code and modified it to pass the correct URI for my camera but it’s resulting in the exact same issue as I have having using @pstuart 's code. It seems like it’s not parsing anything after the hubAction command is executed. Still a little bit over my head with this one, I’m a Mechanical Engineer, not Software! :frowning:
I’m still hitting a brick wall with this. It seems that nothing is being returned to the Parse command when I run the hubAction for the motion detection however when I take a picture it works perfectly. Could someone take a look at my code above to see if there are any obvious issues that I’m just blind to?
I got it to work! because the hubAction was nested within two different actions I had to return the function for it to actually call hubAction. Here is my working device type, it has the ability to take stills from the camera, turn on motion detection, turn on the PIR sensor and change the motion detection sensitivity:
 *	D-Link DCS-942L v1.0
 *  Modified from Generic Camera Device v1.0.07102014
metadata {
	definition (name: "DCS-942L", author: "blebson") {
		capability "Sensor"
		capability "Switch"
        capability "Switch Level"
        capability "Refresh"
        attribute "switch1", "string"
        attribute "switch2", "string"
        attribute "switch3", "string"
        command "motionOn"
        command "motionOff"
        command "pirOn"
        command "pirOff"
    preferences {
	simulator {
    tiles {
        standardTile("refresh", "command.refresh", inactiveLabel: false) {
        	state "default", label:'refresh', action:"refresh.refresh", icon:"st.secondary.refresh-icon"
        standardTile("motion", "device.switch1", width: 1, height: 1, canChangeIcon: false) {
			state "off", label: 'Motion Off', action: "motionOn", icon: "st.motion.motion.inactive", backgroundColor: "#ccffcc", nextState: "toggle"
            state "toggle", label:'toggle', action: "", icon: "st.motion.motion.inactive", backgroundColor: "#53a7c0"
			state "on", label: 'Motion On', action: "motionOff", icon: "st.motion.motion.active", backgroundColor: "#EE0000", nextState: "toggle"
         standardTile("PIR", "device.switch2", width: 1, height: 1, canChangeIcon: false) {
			state "off", label: 'PIR Off', action: "pirOn", icon: "st.custom.buttons.rec", backgroundColor: "#ccffcc", nextState: "toggle"
            state "toggle", label:'toggle', action: "", icon: "st.motion.buttons.rec", backgroundColor: "#53a7c0"
			state "on", label: 'PIR On', action: "pirOff", icon: "st.custom.buttons.rec", backgroundColor: "#EE0000", nextState: "toggle"
       controlTile("levelSliderControl", "device.level", "slider", height: 1, width: 2, inactiveLabel: false, range:"(0..100)") {
            state "level", action:"switch level.setLevel"
        main "motion"
        details(["cameraDetails", "take", "motion", "PIR", "refresh", "levelSliderControl"])
    def map = [:]
	def retResult = []
    def msg = parseLanMessage(description)
    //log.debug "status ${msg.status}"
    //log.debug "data ${msg.data}"
	//Image
    else if (descMap["headers"] && descMap["body"]){
    	def body = new String(descMap["body"].decodeBase64())
        log.debug "Body: ${body}"
    if (msg.body) {
    //log.debug "Motion Enabled: ${msg.body.contains("enable=yes")}"
    //log.debug "Motion Disabled: ${msg.body.contains("enable=no")}"
    //log.debug "PIR Enabled: ${msg.body.contains("pir=yes")}"
    //log.debug "PIR Disabled: ${msg.body.contains("pir=no")}"
        if (msg.body.contains("enable=yes")) {
            log.debug "Motion is on"
            sendEvent(name: "switch1", value: "on");
        else if (msg.body.contains("enable=no")) {
            log.debug "Motion is off"
            sendEvent(name: "switch1", value: "off");
        if (msg.body.contains("pir=yes"))
        	log.debug "PIR is on"
        	sendEvent(name: "switch2", value: "on");
        else if (msg.body.contains("pir=no"))
        	log.debug "PIR is off"
        	sendEvent(name: "switch2", value: "off");
        if(msg.body.contains("sensitivity="))
        	//log.debug msg.body
        	String[] lines = msg.body.split( '\n' )
        	//log.debug lines[2]
            String[] sensitivity = lines[2].split( '=' )
            //log.debug sensitivity[1]
            int[] senseValue = sensitivity[1].toInteger()
            //log.debug senseValue
            sendEvent(name: "level",  value: "${senseValue[0]}")
            //sendEvent(name: "switch.setLevel", value: "${senseValue}")
// handle commands
def take() {
    def host = CameraIP
    def headers = [:]
   	if (CameraAuth) {
    def method = "GET"
    try {
        	method = "POST"
        log.debug e
    try {
    	method: method,
    	path: path,
    	headers: headers
    log.debug hubAction
    hubAction
def motionCmd(int motion, String attr)
    def host = CameraIP
    def path = "/config/motion.cgi?${attr}=yes"
    def headers = [:]
    if (CameraAuth) {
    if (motion == 1){
  try {
    	method: "GET",
    	path: "http://${CameraIP}:${CameraPort}/config/motion.cgi?${attr}=yes",
    	headers: headers
    log.debug hubAction
    return hubAction
  else
  try {
    	method: "GET",
    	path: "http://${CameraIP}:${CameraPort}/config/motion.cgi?${attr}=no",
    	headers: headers
    log.debug hubAction
    return hubAction
def sensitivityCmd(int percent)
    def host = CameraIP
    def pir_percent = []
    if (percent <= 33)
    pir_percent = 0
    else if (percent > 33 && percent < 66)
    pir_percent = 50
    else if (percent >= 66)
    pir_percent = 100
    log.debug "Sensitivity is ${percent} and PIR Sensitivity is ${pir_percent}"
    def path = "/config/motion.cgi?sensitivity=${percent}&pir_sensitivity=${pir_percent}"
    def headers = [:]
    if (CameraAuth) {
  try {
    	method: "GET",
    	path: "http://${CameraIP}:${CameraPort}/config/motion.cgi?sensitivity=${percent}&pir_sensitivity=${pir_percent}",
    	headers: headers
    log.debug hubAction
    return hubAction
    def s3ObjectContent
    try {
        if(imageBytes)
        log.error e
	finally {
	return picName
    return hex
    log.debug hexport
    return hexport
def motionOn() {
	log.debug "Enabling motion detection"
    return motionCmd(1, "enable")
def motionOff() {
    return motionCmd(0, "enable")
def pirOn() {
	log.debug "Enabling PIR Sensor"
    return motionCmd(1, "pir")
def pirOff() {
	log.debug "Disabling PIR Sensor"
    return motionCmd(0, "pir")
def setLevel(percent) {
	log.debug "Executing 'setLevel'"
	return sensitivityCmd(percent)
def refresh(){
	log.debug "Refresh"
    def host = CameraIP
    def path = "/config/motion.cgi"
    def headers = [:]
    if (CameraAuth) {
  try {
    	method: "GET",
    	path: "http://${CameraIP}:${CameraPort}/config/motion.cgi",
    	headers: headers
    log.debug hubAction
    return hubAction
how are you sending the photos. i have this setup but cannot access photos
For the photos that are taken when motion is detected you have to set up an email or FTP connection in the camera’s local settings page (http://{CameraLocalIP}).
When using the ‘take’ command in the devicetype the picture should be shown in the carousel tile at the top.
I had to change the image path to /image/jpeg.cgi and now it is showing in the carousel. I would like to modify it to save the files somewhere. Also is it possible to update the password field so it does not show the password? Thank you
