A friend purchased what he thought was a wifi power strip. He received a Zigbee 4 port power strip with USB ports. I tried adding it to ST but it shows up as the “Thing”.
After researching, and trying to find a custom device handler, all I could find was a Hubitat integration.
Is there a way to convert it to ST? Any help is appreciated.
This is the driver from Hubitat:
* ================== UseeLink SM-SO301-UZ Zigbee Power Strip Driver ====================
* Copyright 2020 Robert Morris
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
* Last modified: 2020-11-16
* Changelog:
* v1.1 - Code formatting improvements and refactoring; more static typing
This file has been truncated. show original
Name
Thing
Label
Thing
Type
Thing
Version
Published
Zigbee Id
EC1BBDFFFE2DAF88
Device Network Id
72EB
Status
ONLINE
Hub
My home Hub
Last Activity At
2021-05-26 9:22 PM EDT
Date Created
Last Updated
Data
* application: 42
endpointId: 01
manufacturer: _TYZB01_vkwryfdr
model: TS0115
zigbeeNodeType: ROUTER |
|Raw Description|01 0104 0009 00 05 0000 000A 0004 0005 0006 01 0019|
|Firmware|Check Now |
|Current States|No states found|
|Execution Location|Cloud|
|Events|List Events |
|In Use By||
Type1Positive:
model: TS0115
This DTH have model TS0115 with 4 ports.
Try the dth linked in this thread, work for several models
Hola @Luis_Mijares ,
I bought a 3-socket Lidl strip and installed it with the DTH “Integrated ZigBee Switch” from your post.
It matched well and works well but I have seen something that I would like to tell you about and that I think could be improved.
Viewing the liveLogging:
According to the DTH configuration, device must send information of status of the 3 plugs every 120 seconds.
Each plug answers between 5 and 60 seconds after the previous one depending on how fast the network was at the time of configuration execution.
The refresh() and healhtpoll() is performed by Schedule every 5 minutes: runEvery5Minutes (“healthPoll”)
Every 10 minutes, the execution of “healthPoll” and the report configuration are send at same time.
This results in excessive information traffic between the …
Thank you so much for pointing me in the right direction. It now works as it should.
