Unlock Interior Door When Garage Door Opens
Hello SmartThings Community!
I’ve hunted around and contacted SmartThings support and have been unable to locate a SmartApp that will allow me to execute the following: When my garage door opens (virtual open/closed sensor), then unlock my door (Schlage deadbolt lock). FYI, I have been able to get this functionality using IFTTT, but I was really hoping to stay within SmartThings to get this done.
I have no experience in writing SmartApps (or coding in general) and wanted to throw this app idea out there for anyone who is up for the challenge … so the community can benefit and, selfishly, so can I!
Any takers?
Cheers,
Jish
I’m pretty sure there is something like this in the IDE, have you taken a look there?
@jish,
Do you know how to look at the shared apps and import them into a new app?
If so, take a look at the shard apps for this one:
Unlock when Garage Door Opens
Just updated the app. Now it’ll send a push notification when the door re-locks (assuming you choose to have it relock). Additionally you can optionally supply an Ubi ACB token and it’ll send a message for Ubi to speak when it locks the door.
@chrisb In the shared apps in IDE, the only “unlock” app I see it “Unlock It When I Arrive”. Do you know what the exact name of the app you wrote is?
@jish,
It should be there now. I think it just takes a while to show up. I see it (right now) is the “Most Recent” category. It should also be in the Safety and Security category.
The name is correct: Unlock when Garage Door Opens.
@chrisb Found it, thank you so much! I can’t wait to test it out when I return home tonight.
Let me know how it works.
I tested it in the simulator but not in “real life” so it’s possible there’s some bugs, but should be good.
@chrisb It worked perfectly … thanks again for sharing this Chris!
I don’t have Ubi, so I ignored those settings. Another feature (or maybe this is another SmartApp on its own) which would be useful to include is the exact opposite: if not locked already, please lock my interior door when my garage door closes and specific presence sensors are away from home.
Hi Chrisb - I’m not finding this app, Unlock when Garage Door Opens, in the Community-created smartapps. Can you please explain where it is or post a link? (I actually want to modify this to Lock a door when the garage door opens, and if I have the code I think I can do that - for a Yale zwave lock?) Thanks.
I used to use this very simple app. It works but I found that just because the door opened does not mean I always want to unlock the front door.
definition(
name: “Garage Door Opening - Unlock Door”,
namespace: “cdikland”,
author: “cdikland”,
description: “Monitor your garage door and unlocks a door when opened”,
category: “”,
iconUrl: “https://s3.amazonaws.com/smartapp-icons/Meta/garage_contact.png”,
iconX2Url: “https://s3.amazonaws.com/smartapp-icons/Meta/garage_contact@2x.png”
preferences {
section(“When the garage door is open…”) {
input “garageDoor”, “capability.contactSensor”, title:“Which door?”
input “lock”, “capability.lock”, title:“Unlock Which lock?”
def installed()
subscribe(garageDoor, “contact.open”, handleOpenDoorEvent)
def updated()
unsubscribe()
def handleOpenDoorEvent(evt) {
lock.unlock()
