I can’t create automations in the app. When I try to save the automation, the app says “A network or server error occurred. Please try again later.”. I’ve tried it a bunch of times.
I’ve had this before. When you save don’t change the name and then go back into it after and rename. Worked for me, see how you go.
Thanks for the fast reply! I wish it was that easy. I haven’t been changing the name.
Sorry I wasn’t able to help, hopefully someone else may have a solution or you may have to raise a ticket. Best of luck
- try clearing the app cache
- try using cellular connection only with your mobile device
- have you attempted setting up an automation with different set of devices and rules to see if you are successful?
- logout of the app and log back in.
Just taking a stab in the dark…
Yes thanks for all of those ideas but I’ve done all of them. This issue has lasted multiple phones for me.
I responded via DM. I believe this is an issue with default location confusion and the mobile app trying to create an automation across locations, meaning the automation is trying to utilize a device on Location A as well as a device on Location B.
