UK Lighting Query
Afternoon all,
I’m after a little advice regarding some wiring setup so that I can ensure it does what I want and before I buy the kit for me electrician to fit. This is for a UK setup. As this deals with lighting I’m aware of the various UK specific lighting FAQ threads but I can’t find the right answer from these that I can be confident will work.
Current Setup
  • Single 1 gang light switch connected to a standard light fitting (3 x 40W max LED bulbs). 3 wire setup.
Desired Setup
  • Convert standard switch connected to standard light fitting to a smart solution. I need to ideally be able to dim the lights fitting via a physical switch (and it has to be 'normal’ looking dimmer for the WAF) and dim via ST. I don’t believe this is possible so I’m willing to accept a smart on/off solution as long as it can be controlled by physical button and ST.
  • Addition of 2 x Hue GU10 and 2 x Hue lightstrips. This will ultimately be linked to my AV setup and I would like a physical switch so that there is the option for these lights to not be active all the time. Obviously this needs to be something which won’t cut the power to the Hues as they need to be powered 24/7
Objectives
  • Needs to have WAF - nice looking switches/dimmers (ideally chrome)
  • Have physical switches and ability to control via ST
  • Lighting setup for home theatre, with ability to turn this off when not required
I’m thinking the MCO Home touch panel 2 gang might fit the bill. If I was to get this could I wire one load to the existing light fitting and give me the ability to turn this off via physical switch and ST, and then use the 2nd switch on the panel purely as a z-wave switch to turn hues on and off via WebCore?
If not, does a physical switch/relay exist which I would get wired in and would be able to dim the hues but not actually cut power to them?
Hope that all makes sense. Any help will be greatly appreciated.
Ade
If you are open to another hub, then have a look at LightwaveRF. Just replace your existing switches. They also do a slave so you can have 2-way switches.
They do various colours.
You can configure cloud to cloud so ST can control them or you can install a Raspberry Pi to remove the cloud.
So you can control these manually (finger method :wink: ) or use ST for home automation.
Plenty of other options out there but personally this is my setup and my favourite. (I would say that wouldn’t I. I’m not a LightwaveRF employee or shareholder BTW).
https://www.lightwaverf.com/solution/smart-home/
Thanks Bob,
Appreciate the reply. I have looked at Ightwave but I’m not eager to have another hub/integration to add a further link.
Thanks for the reply
Ade
I recommend the Fibaro Dimmer 2 modules. I have many and they work with or without a neutral. There is a really good device handler available. The dimmer 2 can be used with momentary or toggle switches, although for dimming its easier to use momentary switches.
There are a number of momentary switches available with many discussed on the forum. I have not tested these, but Varilight do a range of momentary switches. I had their V-plus IR installed successfully for over 10 years so hopefully the momentary are just as reliable.
Last thing. are you sure you have 3-wire in your switches? Its not common in the UK. Most of the time you just have a Live and return to the ceiling rose. this is one reason why Fibaro are popular here.
Thanks @siwilson,
Appreciate the advice.
I’m pretty sure my electrician said it was 3-wire but let me check - part of the house has been re-wired so this maybe different to the location I want to put these switches in.
Thanks @anon36505037,
With regards to controlling the Hue’s, are you referring to the idea of supplying power to the fibaro module but not connecting a load to it? i.e. simply using it as a smart switch. This way the Hue’s won’t power off and ‘drop off’ the network.
Hhmmm.
Not seen the varilight switches before.
I have a spare Fibaro dimmer so I may order one and see how it integrates.
That seems to answer so many questions; can reuse existing wiring, no need to chip out, can control and physical and virtual device, can use normal light switches. All I need is a larger back box and to find some suitable switches.
One quick question though. Vesternet specify that a 2 way & off switch can be used to allow dimming up and down:
http://www.vesternet.com/resources/application-notes/apnt-113
I assume this dimming is performed by the fibaro module so will work with ST? Also ( and more importantly) does anyone know if this will remove the ability for me to use the second switch to control scenes? The diagram on vesternet shows both S1 and S2 being connected.
Thanks in advance
Thanks so much @anon36505037,
Perfect and clear answers to everything I’ve asked. Over the past couple of days you’ve helped cleared up so points of confusion I’ve had for weeks, so thank you again. A credit to the community.
Right, I’m off to buy a Fibaro dimmer and a 2 gang retractive switch :slight_smile:
Just in case you want to get MCO, they doesn’t work well with ST
Just before I put my cash down, would someone mind confirming that the Varilight XFCM2 momentary switch will fit the bill. I’ve taken a look at documentation ( and found a photo during searches, attached) and it doesn’t appear to have a common, on L1 and L2. This is pretty contrary to what else I’ve read is required.
Thanks in advance
Ade
