I have a TuyaSmart water sensor the I have added and working on TuyaSmart app.
But when trying to add to ST app it says device added to this account but it never shows up.
Try bringing the device closer to the hub (assuming it’s a ZigBee device). If the pairing doesn’t complete it may not show up or show up much later.
Well I believe that the device is Wi-Fi sense I had to pair it with the TuyaSmart app through 2.4ghz Wi-Fi and it works and shows up fine in Tuyasmart app, it seems that SmartThings is not linking the Tuyasmart app device correctly.
If it’s wifi you’ll have to contact Tuya as they control the integration
If you open each device in the Smartlife/Tuya app and hit the edit icon it will list the “3rd party controls” that are available for that device.
I have 5 Smartlife devices. They all list Alexa and Google controls. Only 1 lists Smartthing.
Another option is to create a scene in the tuya app that incorporates your water sensor, one scene for dry and one scene for wet, I’m assuming that’s possible as I don’t have a water sensor, then go back to ST and see if the scenes appear in the Tuya integration and as devices for on off
I have some devices not listed as ST compatible but they show up as scenes
