Turn on light if we leave and it's night time
I’d like a specific light to turn on when all the key fobs leave the house and it’s night time. I setup a routine under Automation, but it triggers whenever we all leave no matter the time of day. What’s the best way to set this up?
SmartLighting will do this with Arrival/Departure option and then click + More Options and select In Between Sunset and Sunrise or whatever time frame you specify.
However, I have found CoRE to be more reliable. CoRE runs through the cloud while SmartLighting runs locally so it is faster.
Here is a CoRE Piston that does sorta the opposite with a timer but you can adjust for your situation.
The SmartLighting app will allow you to do that.
SmartApps --> Add a Smart App --> SmartThings Recommends --> Smart Lights
Under more options set it to only run between X pm- y AM , or only between sunset & sunrise.
I utilized the SmartApps SmartLighting function. Thank you all very much for your time.
