Turn off a device if windspeed is too high
I have a Christmas inflatable decoration plugged into a zwave outlet connected to my smartthings hub. I would like to control it in the following way:
If windspeed is < 10 mph and it is sunset, turn on
If windspeed exceeds 10 mph between sunset and 11pm turn off
At 11pm turn off
I can get the sunrise sunset rules no problem. I can even get the windspeed sort of with IFTTT. However, the IFTTT recipe doesn’t run frequently enough. Today, the decoration turned on even though the windspeed was 15mph.
Any suggestions?
I believe there is a Weather SmartApp that may help you pull weather info directly and act on it instead of through IFTTT, I do not have experience with it though so not sure if the functionality you require is there?
I think you might get there with Neatmo? I am not sure of the parameters and variables, but it may be worth some more investigation. IFTTT works with Neatmo, and there is an old "smartthings lab’ integration I found.
Edit - Nevermind. The wind module is not yet available. I would suggest lowing the threshold?
https://www.netatmo.com/en-US/product/weather-station/accessories
and
If you are using an Android you might be able to get something together with the Weather tile, Sharptools/Tasker, a virtual on/off switch and Rule Machine. Sounds like a lot of moving parts but it shouldn’t be that hard to setup. The key is that Sharptools can subscribe to the “wind” parameter of the weather tile.
Is it possible to connect the wind gauge to Smart Things without a Netatmo hub?
