I have managed to configure the Hue Outdoor Motion sensor directly with an ST hub and by changing a value in the indoor sensor DH, I now have the outdoor sensor working in the ST environment.
I am now at a loss as to how to manage the next step.
I want to play a sound on my Alexa device when the motion sensor is triggered.
I can see the device in Alexa but if I try to set up a routine, it tells me that it can’t use the sensor as a trigger.
I can create an automation on the ST app which is triggered when motion is detected but I can seem to get it to ‘do’ playing a sound.
Any ideas?
Mine works fine, but it’s connected through the hue bridge, I’m not sure if that would make a difference.
The only thing I can think of is to try the steps on “activating your device” in the community FAQ. They have to be done in a specific sequence, so even if you think you already did some steps, do them again just as written. In your case start with step 2 in that section since you aren’t using a virtual device.
https://thingsthataresmart.wiki/index.php?title=How_to_use_SmartThings_to_have_Alexa_do_something_without_speaking_to_it
If that doesn’t work, it has to be the DTH. I suppose worst case you could create a virtual sensor as a proxy as discussed in the FAQ, but hopefully you won’t need it.
I looked at your post and went back in to the Alexa app and the sensor now supports ‘Motion Detected’ and ‘No Motion Detected’ activities rather than the error message I got earlier.
No idea what had happened in the past few hours but it has suddenly worked out how to use the sensor!
can anyone confirm that the outdoor hue motion sensor work with the smartthings v2 hub?
