This is not how you connect it.
I would delete the device that you have just defined.
Then go to the sensor and reset it. This is done through the pinhole at the back if I remember correctly.
When it has been factory reset, go the the app, under the ‘things’ tab you will see ‘Add a Thing’.
Click on it and the hub is now in discovery mode.
No press the button through the reset hole to get the device into pairing mode.
I think the sensor starts to flash orange.
ST should now find the sensor.
Good luck.
EDIT: I’m assuming you have installed the Device Handler.
This is the one I use.
* Copyright 2015 SmartThings
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
metadata {
definition (name: "Hue Motion Sensor", namespace: "digitalgecko", author: "digitalgecko") {
capability "Motion Sensor"
capability "Configuration"
capability "Battery"
capability "Refresh"
capability "Temperature Measurement"
capability "Sensor"
capability "Illuminance Measurement" //0x0400
fingerprint profileId: "0104", inClusters: "0000,0001,0003,0406,0400,0402", outClusters: "0019", manufacturer: "Philips", model: "SML001", deviceJoinName: "Hue Motion Sensor"
preferences {
section {
input title: "Temperature Offset", description: "This feature allows you to correct any temperature variations by selecting an offset. Ex: If your sensor consistently reports a temp that's 5 degrees too warm, you'd enter '-5'. If 3 degrees too cold, enter '+3'.", displayDuringSetup: false, type: "paragraph", element: "paragraph"
input "tempOffset", "number", title: "Degrees", description: "Adjust temperature by this many degrees", range: "*..*", displayDuringSetup: false
tiles(scale: 2) {
multiAttributeTile(name:"motion", type: "generic", width: 6, height: 4){
tileAttribute ("device.motion", key: "PRIMARY_CONTROL") {
attributeState "active", label:'motion', icon:"st.motion.motion.active", backgroundColor:"#53a7c0"
attributeState "inactive", label:'no motion', icon:"st.motion.motion.inactive", backgroundColor:"#ffffff"
valueTile("temperature", "device.temperature", width: 2, height: 2) {
state("temperature", label:'${currentValue}°',
backgroundColors:[
[value: 31, color: "#153591"],
[value: 44, color: "#1e9cbb"],
[value: 59, color: "#90d2a7"],
[value: 74, color: "#44b621"],
[value: 84, color: "#f1d801"],
[value: 95, color: "#d04e00"],
[value: 96, color: "#bc2323"]
valueTile("battery", "device.battery", decoration: "flat", inactiveLabel: false, width: 2, height: 2) {
state "battery", label:'${currentValue}% battery', unit:""
valueTile("illuminance", "device.illuminance", width: 2, height: 2) {
state("illuminance", label:'${currentValue}', unit:"lux",
backgroundColors:[
[value: 9, color: "#767676"],
[value: 315, color: "#ffa81e"],
[value: 1000, color: "#fbd41b"]
standardTile("refresh", "device.refresh", inactiveLabel: false, decoration: "flat", width: 2, height: 2) {
state "default", label:"", action:"refresh.refresh", icon:"st.secondary.refresh"
standardTile("configure", "device.configure", inactiveLabel: false, decoration: "flat", width: 2, height: 2) {
state "default", label:"configure", action:"configure"
main "motion"
details(["motion","temperature","battery", "refresh","illuminance",'configure'])
// Parse incoming device messages to generate events
def msg = zigbee.parse(description)
//log.warn "--"
//log.trace description
//log.debug msg
//def x = zigbee.parseDescriptionAsMap( description )
//log.error x
Map map = [:]
if (description?.startsWith('catchall:')) {
map = parseCatchAllMessage(description)
else if (description?.startsWith('temperature: ')) {
map = parseCustomMessage(description)
else if (description?.startsWith('illuminance: ')) {
// else if (description?.startsWith('zone status')) {
// //map = parseIasMessage(description)
// log.trace "zone status"
def result = map ? createEvent(map) : null
if (description?.startsWith('enroll request')) {
List cmds = enrollResponse()
result = cmds?.collect { new physicalgraph.device.HubAction(it) }
else if (description?.startsWith('read attr -')) {
result = parseReportAttributeMessage(description).each { createEvent(it) }
return result
Refresh Function
def refresh() {
log.debug "Refreshing Values"
def refreshCmds = []
refreshCmds +=zigbee.readAttribute(0x0001, 0x0020) // Read battery?
refreshCmds += zigbee.readAttribute(0x0402, 0x0000) // Read temp?
refreshCmds += zigbee.readAttribute(0x0400, 0x0000) // Read luminance?
refreshCmds += zigbee.readAttribute(0x0406, 0x0000) // Read motion?
return refreshCmds + enrollResponse()
Configure Function
def configure() {
// TODO : device watch?
String zigbeeId = swapEndianHex(device.hub.zigbeeId)
log.debug "Confuguring Reporting and Bindings."
def configCmds = []
configCmds += zigbee.batteryConfig()
configCmds += zigbee.temperatureConfig(30, 600) // Set temp reporting times // Confirmed
configCmds += zigbee.configureReporting(0x406,0x0000, 0x18, 30, 600, null) // motion // confirmed
// Data type is not 0x20 = 0x8D invalid data type Unsigned 8-bit integer
configCmds += zigbee.configureReporting(0x400,0x0000, 0x21, 60, 600, 0x20) // Set luminance reporting times?? maybe
return refresh() + configCmds
getMotionResult
private Map getMotionResult(value) {
//log.trace "Motion : " + value
def descriptionText = value == "01" ? '{{ device.displayName }} detected motion':
'{{ device.displayName }} stopped detecting motion'
return [
value: value == "01" ? "active" : "inactive",
descriptionText: descriptionText,
translatable: true,
getTemperatureResult
private Map getTemperatureResult(value) {
//log.trace "Temperature : " + value
if (tempOffset) {
def offset = tempOffset as int
def v = value as int
value = v + offset
def descriptionText = temperatureScale == 'C' ? '{{ device.displayName }} was {{ value }}°C':
'{{ device.displayName }} was {{ value }}°F'
return [
value: value,
translatable: true,
unit: temperatureScale
def getTemperature(value) {
def celsius = Integer.parseInt(value, 16).shortValue() / 100
if(getTemperatureScale() == "C"){
return Math.round(celsius)
} else {
return Math.round(celsiusToFahrenheit(celsius))
private Map getLuminanceResult(rawValue) {
log.debug "Luminance rawValue = ${rawValue}"
def result = [
value: '--',
translatable: true,
unit: 'lux'
result.value = rawValue as Integer
return result
getBatteryResult
//TODO: needs calibration
private Map getBatteryResult(rawValue) {
//log.debug "Battery rawValue = ${rawValue}"
def result = [
value: '--',
translatable: true
def volts = rawValue / 10
if (rawValue == 0 || rawValue == 255) {}
else {
if (volts > 3.5) {
result.descriptionText = "{{ device.displayName }} battery has too much power: (> 3.5) volts."
else {
if (device.getDataValue("manufacturer") == "SmartThings") {
volts = rawValue // For the batteryMap to work the key needs to be an int
def batteryMap = [28:100, 27:100, 26:100, 25:90, 24:90, 23:70,
22:70, 21:50, 20:50, 19:30, 18:30, 17:15, 16:1, 15:0]
def minVolts = 15
def maxVolts = 28
if (volts < minVolts)
volts = minVolts
else if (volts > maxVolts)
volts = maxVolts
def pct = batteryMap[volts]
if (pct != null) {
result.value = pct
result.descriptionText = "{{ device.displayName }} battery was {{ value }}%"
else {
def minVolts = 2.1
def maxVolts = 3.0
def pct = (volts - minVolts) / (maxVolts - minVolts)
def roundedPct = Math.round(pct * 100)
if (roundedPct <= 0)
roundedPct = 1
result.value = Math.min(100, roundedPct)
return result
parseCustomMessage
private Map parseCustomMessage(String description) {
Map resultMap = [:]
def value = zigbee.parseHATemperatureValue(description, "temperature: ", getTemperatureScale())
resultMap = getTemperatureResult(value)
log.warn "value: " + description.split(": ")[1]
log.warn "proc: " + value
def value = zigbee.lux( description.split(": ")[1] as Integer ) //zigbee.parseHAIlluminanceValue(description, "illuminance: ", getTemperatureScale())
resultMap = getLuminanceResult(value)
return resultMap
private List parseReportAttributeMessage(String description) {
Map descMap = (description - "read attr - ").split(",").inject([:]) { map, param ->
def nameAndValue = param.split(":")
map += [(nameAndValue[0].trim()):nameAndValue[1].trim()]
List result = []
// Temperature
if (descMap.cluster == "0402" && descMap.attrId == "0000") {
def value = getTemperature(descMap.value)
result << getTemperatureResult(value)
// Motion
else if (descMap.cluster == "0406" && descMap.attrId == "0000") {
result << getMotionResult(descMap.value)
// Battery
else if (descMap.cluster == "0001" && descMap.attrId == "0020") {
result << getBatteryResult(Integer.parseInt(descMap.value, 16))
// Luminance
else if (descMap.cluster == "0402" ) { //&& descMap.attrId == "0020") {
log.error "Luminance Response " + description
//result << getBatteryResult(Integer.parseInt(descMap.value, 16))
return result
private Map parseCatchAllMessage(String description) {
Map resultMap = [:]
def cluster = zigbee.parse(description)
// log.debug cluster
if (shouldProcessMessage(cluster)) {
switch(cluster.clusterId) {
case 0x0001:
// 0x07 - configure reporting
if (cluster.command != 0x07) {
resultMap = getBatteryResult(cluster.data.last())
break
case 0x0400:
if (cluster.command == 0x07) { // Ignore Configure Reporting Response
if(cluster.data[0] == 0x00) {
log.trace "Luminance Reporting Configured"
sendEvent(name: "checkInterval", value: 60 * 12, displayed: false, data: [protocol: "zigbee", hubHardwareId: device.hub.hardwareID])
else {
log.warn "Luminance REPORTING CONFIG FAILED- error code:${cluster.data[0]}"
else {
log.debug "catchall : luminance" + cluster
resultMap = getLuminanceResult(cluster.data.last());
break
case 0x0402:
log.trace "Temperature Reporting Configured"
else {
log.warn "TEMP REPORTING CONFIG FAILED- error code:${cluster.data[0]}"
else {
// temp is last 2 data values. reverse to swap endian
String temp = cluster.data[-2..-1].reverse().collect { cluster.hex1(it) }.join()
def value = getTemperature(temp)
break
return resultMap
private boolean shouldProcessMessage(cluster) {
// 0x0B is default response indicating message got through
boolean ignoredMessage = cluster.profileId != 0x0104 ||
cluster.command == 0x0B ||
(cluster.data.size() > 0 && cluster.data.first() == 0x3e)
return !ignoredMessage
// This seems to be IAS Specific and not needed we are not really a motion sensor
def enrollResponse() {
// log.debug "Sending enroll response"
// String zigbeeEui = swapEndianHex(device.hub.zigbeeEui)
// //Resending the CIE in case the enroll request is sent before CIE is written
// "zcl global write 0x500 0x10 0xf0 {${zigbeeEui}}", "delay 200",
// "send 0x${device.deviceNetworkId} 1 ${endpointId}", "delay 500",
// //Enroll Response
// "raw 0x500 {01 23 00 00 00}", "delay 200",
// "send 0x${device.deviceNetworkId} 1 1", "delay 200"
def configureHealthCheck() {
Integer hcIntervalMinutes = 12
refresh()
sendEvent(name: "checkInterval", value: hcIntervalMinutes * 60, displayed: false, data: [protocol: "zigbee", hubHardwareId: device.hub.hardwareID])
def updated() {
log.debug "in updated()"
def ping() {
return zigbee.onOffRefresh()
private getEndpointId() {
new BigInteger(device.endpointId, 16).toString()
private String swapEndianHex(String hex) {
reverseArray(hex.decodeHex()).encodeHex()
private byte[] reverseArray(byte[] array) {
int i = 0;
int j = array.length - 1;
byte tmp;
while (j > i) {
tmp = array[j];
array[j] = array[i];
array[i] = tmp;
j--;
i++;
return array
