Tapo P110M (UK) Matter 1.3 but no Energy Monitoring
Yesterday I got the Matter 1.3 update on my SmartThings hub and I was hoping to see energy monitoring being supported with my Tapo P110M but unfortunately this is not the case.
Tapo P110M | Mini Smart Wi-Fi Plug, Energy Monitoring | Tapo
Tapo P110M and SmartThings as of today:
  • Using the Tapo Linked services, energy Monitoring works but then the control is not local.
  • Using Matter 1.3, energy monitoring is NOT working
I want the control to remain local but also have energy monitoring and be able to use Multi-Admin and therefore I want to use Matter.
I’ll also report this to Tapo as I suspect they need to push a firmware update.
How can I use energy monitoring of the TP-Link plug in SmartThings | Tapo:
Since the Energy feature of SmartThings currently does not support dimmer devices, the energy monitoring of the TP-Link Dimmers (like S515D) is not available within the SmartThings at this time.
Anyone who also want this to work? Please like this message.
Anyone with other Matter Smart Plugs that got their energy monitoring working?
There’s already a feature request in the official forum, vote for it!
Done!
Thank you.
As s temporary solution you can use both the Matter integration and the c2c integration.
This will give you 2 devices in ST. One for local control (Matter device) and one for power monitoring (c2c device).
That’s what I’m doing now but not the most elegant solution :smiley:
Thanks for the suggestion, it can help others
It is confirmed the P110M is getting the Matter 1.3 update with energy and power reporting. Got the Matter certification yesterday, don’t mind the ā€œpower stripā€ text, it is the P110M.
The date for the actual firmware update is not announced though, it can be weeks…
When the firmware is eventually updated, I believe the SmartThings driver will not detect the new monitoring features since it only checks the features in the configure lifecycle which happens usually only once when setting it up. However, maybe the platform is smart enough to trigger that lifecycle event when the firmware version changes, we will see!
(OK, let’s ask @nayelyz out of curiosity :see_no_evil_monkey:: if a Matter device gets a firmware update to add new features / clusters, like energy reporting in this case, will the configure lifecycle be called again?)
I feel that the SmartThings Edge Device Drivers Reference Documentation would be better served by something a little more forthcoming than the current slightly mangled offering of ā€˜there are other protocol specific cases that this may be triggered as well.’ Shouldn’t ā€˜Reference Documentation’ be detailing what these cases are?
It should be a Wiki anyway, but I think it’s too late to change that.
Hi, @mocelet
I asked the engineering team and they mentioned a firmware update wouldn’t trigger the configuration lifecycle, in that case, you would need to re-install it.
Thanks @nayelyz , reinstalling will be indeed the only option if they don’t plan to fix the drivers.
Feels like they could update the driver to change the profile automatically, after all it’s going to subscribe to the power monitoring and emit the capability events, except that it will just generate errors since the capability is not in the profile.
And the day arrived, there’s a beta firmware for the P110M that adds power monitoring and SmartThings will not change the profile to add the power or energy capabilities because it only assigns the profile in the configure lifecycle when it is first added, forcing the user to re-install the device.
This is from the TP-Link forum:
the plugs that have the upgraded firmware (to the beta version) don’t show power or energy. If I take a plug which has the beta firmware and add it as a fresh new plug into SmartThings then the power and energy are exposed
Edit: So, I thought they were working on it, but turns out they are not:
At first glance I thought they would change the profile when the Power Topology changed, but turns out they only read the power and energy endpoints on added lifecycle. Again, same mistake that will prevent existing devices to re-profile when they get a firmware upgrade to add features like power monitoring.
I honestly would consider that a bug, having to reinstall a device because it gained new features like power monitoring is not the expected user experience.
