There’s a 20% off coupon good for one order at the link below:
RLDreams
(Really Living the Dream)
September 17, 2018, 6:20am
4
I was tempted, but I already have 7 of them and really can’t think of any place else I could use them.
Francky
September 17, 2018, 8:32am
5
Thanks for sharing.
Bought 2 starter kit and 2 extensions but had to place individual orders to have 20% on each item.
eric182
(Eman ym)
September 17, 2018, 10:16am
6
Thanks, but I don’t need anymore. If I add any more of these to my property, my house will look distasteful. Less is better if you know what I mean
xamindar
(Jared)
September 17, 2018, 10:26am
7
Not sure what a Gardensots is, but great deal, picked some more up!
kevin
(Kevin)
September 17, 2018, 2:28pm
8
Looks like they are all gone
I searched around a bit but couldn’t find a good overview of these…
-How do these hold up over time in the rain/snow/heat?
-Do they light up what is above them, or just the bulb itself glows? In some videos seems like just the bulb.
-are there any special features of their hub (fade between colors?), or can ST with apps/webcore cover everything?
eric182
(Eman ym)
September 17, 2018, 2:50pm
9
I’ve had mine for 2 years outside in hot summers and cold winters with no issues. They even turn on when buried in 1+ foot of snow. You can use a special DTH to get them to fade, not the stock DTH
This thread has more examples and the custom DTH
Osram LIGHTIFY GardenSpot Mini rgb - AAP Version
A new version of the DTH for Osram GardenSpot Mini rgb lights (based on @Sticks18 ’s version).
This DTH is for directly connecting the US (Z HA) versions to SmartThings.
Without the Osram Gateway, the color loop functionality does not work for the US version of the GardenSpots (at least until they update the firmware).
But using the “hueLoop” and “hueRandom” attributes of this DTH, one create a CoRE Piston to cause color loop (even random colors) Device Tile contains sliders for individual control of hue, saturation, and transition time. Device Tile also contains buttons for (1) “hueLoop” (boolean “on” / “off” values) and (2) “Random Hue” (causes hue to change to a random color). Use these in CoRE to create color loop.
You can find th…
Here’s a smart app that will automatically schedule US holiday colors once the lights are turned on.
I actually just did something like this for myself, but w/ a smartapp. I’m using it for flexstrips, but should work w/ gardenspots as well as other rgbw devices. Its has preconfigured holidays, with colors (and easy enough to add/change your own), and is designed to pick the closet holiday (w/ some options). Yes I’m that lazy.
still playing with it though.
