I recently got my EU kickstarted hub and I am trying to get a Fibaro Smoke sensor to work, but can’t figure out what is happening, so does anyone know if it’s supported, and if not is there some debug tools so I can write a device handler for it?
I already played around with some custom devices for a spark core and some other examples, but the documentation section is very limited so it’s kind of hard to research on your own
same here. I have been able to get the Fibaro smoke sensor included but it’s shown as an inactive sensor (not as a smoke detector) and therefore it doesn’t work.
I definitely hope that someone (from smartthings?) can help.
the forum does not let me upload pictures but i could show screenshots from the API website of smartthings. maybe that would help.
in any case, any help/idea/support is greatly appreciated.
One more thing: I have also bought and successfully included one of the Fibaro Power Switches. So it must be something with the smoke detector that’s not working properly with smartthings.
Hey, I’m working with smartthings on a solution. We are close but not there yet. Andrew from smartthings is a great help but it seems he is the only one in the team being able to help and that means his time is very limited.
once we have a solution, we will of course post it here…
@alex
Can you shed some light on this integration?
I do believe that safety items like a Smoke Detector should be a priority item to integrate into the Smartthings system, and these safety and security items should be a higher priority than some of the tech-toys that are being discussed in the developer hour calls.
