Hi,
I’m developing an app that controls SmartThings using their external API access.
I can’t find the place where I can submit it for review. At the moment the number of OAuth connections is limited.
How can I get this number increase?
Hi @shahar_wienrib! The form that was mentioned is this, the requests are reviewed on a daily basis so it wouldn’t take too long.
You won’t need nor Test or Publish given that the integration is actually on your side. You’ll be able to use it from the first moment you deploy your service!
Hi @shahar_wienrib, the initial amount of clients that can connect is 20, when you are close to reaching the limit and if you need more, you can create a request to support for an increase.
Vu.Q.Nguyen
(ThingsTwin SmartThings on Floorplan UI)
9
Hi. Also about SmartApp seem we also have the limit number of 20 subscriptions per installed SmartApp, is it correct? If so, can I request to increase this limit number, too? Thank you.
