Stuck on flashing blue v3 hub
Hi, I’m stuck in flashing blue after resetting my hub. Tried everything, any help??
which model hub do you have?
curious - why did you reset it?
have you tried powering it down (removing batteries if v2) for a minute and powering it back up?
Blinking Blue
There is no Ethernet or WiFi connection. This can happen if you allow Smart Home Hub to timeout its setup process.
Simply unplug your hub, and then re-plug your hub. If using WiFi, try connecting it to Ethernet.
Info from
V3, tried removing power source a couple of times and nothing new, tried resetting again and nothing, still flashing blue
Have been doing this several times, nothing, plugged in to Ethernet cable, reset router, changed cables, nothing
best recommendation is to contact ST support and lert them investigate
did you try connecting by wifi instead of ethernet?
Yes, seems to have lost wifi as well.
I also have the same problem, the hub never worked.
It’s a V3 ST.
I’ve done several resets and it always flashes blue.
More details… any error codes, new hub or existing hub?
New hub.
On the Wi-Fi, it just blinks blue and doesn’t find the hub.
On the Ethernet cable, it stays green and also gives an error in the app.
Error: 33-301
In both cases, I reset the hub, holding the button and waiting for the yellow to stop blinking.
Perfect my friend!
Blocking the NTP port solved my problem and I was able to add the hub.
Thank you very much!
